Installation & Licensing
*Knudsen, Michael
Message 1 of 5 (252 Views)
AdlM, Novell 5 TCP/IP and NT Workstation
252 Views, 4 Replies
09-29-1999 04:42 AM
Hello!
When using AdlM Admin (TCP/IP Create Floating License) I don't get the
Server Code.
I do enter Key Directory: \\vf-prim\sys\adlm\key and Host Name: vf-prim.
I only get the error: Could not generate server code for vf-prim. Manually
enter Server Code.
Michael Knudsen
*[Autodesk], jerry milana
Message 2 of 5 (252 Views)
Re: AdlM, Novell 5 TCP/IP and NT Workstation
09-29-1999 09:19 AM in reply to: *Knudsen, Michael
Michael,
The Netware version of AdLM only works with IPX protocol, it does not use
TCP/IP. If you wish to use TCP/IP on your Netware server, AdLM would have to
reside and run on a Windows system, where AdLM does use TCP/IP.
Jerry Milana,
Autodesk Product Support
Michael Knudsen wrote:
> Hello!
> Server Code.
> enter Server Code.
> Michael Knudsen
*Knudsen, Michael
Message 3 of 5 (252 Views)
Sv: AdlM, Novell 5 TCP/IP and NT Workstation
10-01-1999 04:58 AM in reply to: *Knudsen, Michael
Thank you!
Dos the AdlM have to run on a NT Server or is it ok on a NT 4.0 Workstation?
Best Regards
Michael Knudsen
A/S Vestfrost, Denmark
jerry milana [Autodesk] skrev i en
nyhedsmeddelelse:37F23BF7.757167B4@autodesk.com...
> Michael,
to
> Jerry Milana,
> > Hello!
> > Server Code.
Manually
> > enter Server Code.
> > Michael Knudsen
*Schroeder, Bud
Message 4 of 5 (252 Views)
10-01-1999 10:17 PM in reply to: *Knudsen, Michael
Hi Michael,
You can use it on NT, 95 or 98 workstation as a license manager.
Hope this helps.
Bud
> Thank you!
> Best Regards
> Michael Knudsen
> > Michael,
> to
> > Jerry Milana,
> > > Hello!
> > > Server Code.
> Manually
> > > enter Server Code.
> > > Michael Knudsen
*Milana, Jerry
Message 5 of 5 (252 Views)
10-02-1999 12:58 AM in reply to: *Knudsen, Michael
To clarify Bud's answer, AdLM uses a connectionless protocol (udp) so the user
connection limit for NT Workstation does not apply. NT Workstation will work just
fine and is preferable over Windows 95 or 98. The reason is that on W 95 & 98,
someone must be logged in to the AdLM server for the license manager to be
active. On NT, AdLM will be active regardless of anyone being logged on to the
system.
Jerry
Bud Schroeder wrote:
> Hi Michael,
> Hope this helps.
> Bud
> > Thank you!
> > Best Regards
> > Michael Knudsen
> > > Michael,
> > to
> > > Jerry Milana,
> > > > Hello!
> > > > Server Code.
> > Manually
> > > > enter Server Code.
> > > > Michael Knudsen
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
