I have been running a single license on a stand alone server for Autocad 2011 with LMTOOLS. I recently activated another license online and recieved the .lic file. How do I append both license files together to work? Instructions say something about appending after the increment data but dont explain how to do that? Thanks!!
It will not work unless you also get your older AutoCAD 2011 license recreated on the same day as your new LIC file. At that point, you simply need to copy the INCREMENT portion of file and append it to the other. Remember, this will only work if both licenses are created on the same day, otherwise the newer license will always supersede the older one. Autodesk can combine these for you if you ask. 1-800-551-1490.
