• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    hgu
    New Member
    AdLM will not start on a Windows 2000 Server
    101 Views, 3 Replies
    07-04-2000 01:51 AM
    AdLM was intalled on a Win2000 Server without problems. When we attempted to start it (both automatic and manual)
    we got the following error:
    Could not start ad:elmd.exe check system log for reason.
    In this log the following was stated:
    Only one usage of each socket adress (protocol/network/adress/port) is normalt admitted
    Any idea out there? We have gone trough the usual checks (multiple network cards, RAS modems, port adresses)
    Please use plain text.
    *Hurley, Shaan
    Re: AdLM will not start on a Windows 2000 Server
    07-05-2000 05:38 AM in reply to: hgu
    Please check the online Knowledge Base for the documented solution.
    (copy the entire URL to your browser)
    http://www3.autodesk.com/adsk/support/techdoc/0,,157553--125452-20022_21837,
    00.html
    Sincerely,
    Shaan Hurley
    Autodesk Beta Programs
    http://betaprograms.autodesk.com
    "hgu" wrote in message
    news:ef281d4.-1@WebX.SaUCah8kaAW...
    normalt admitted
    *milana, jerry
    Re:
    07-05-2000 10:23 AM in reply to: hgu
    Harald,
    Actually, I do not think the Knowledge Base item Shaan points you to is
    going to help much yet. That item deals with a DLL problem on Windows 2000
    AutoCAD clients.
    Your problem appears to be that some service is already grabbing udp port
    1422. Autodesk has registered udp 1422, so any other service that happens
    to be using this port is stepping outside of convention. Your best bet to
    resolve this problem (unless you already know what is using udp 1422) is to
    review all services running on your server and turn off everything that did
    not come with the operating system. Then try AdLM, which should start.
    Next turn on one service at a time until AdLM will not start again. Once
    you find the offending service, contact the developer and ask them to switch
    which port they use, explaining that 1422 is registered to Autodesk.
    Jerry Milana,
    Autodesk Product Support
    "Shaan Hurley" wrote in message
    news:ef281d4.0@WebX.SaUCah8kaAW...
    > 00.html
    > Sincerely,
    > Shaan Hurley
    attempted
    > normalt admitted
    network
    *milana, jerry
    Re:
    07-05-2000 10:42 AM in reply to: hgu
    By the way, you can confirm that rouge udp 1422 usage is in fact your
    problem by entering the following at a command prompt (DOS Window):
    netstat -a -p udp
    In the output look for a line like:
    UDP paradise:1422 *:*
    where paradise is the hostname of the system. If udp 1422 shows up on this
    report, something is using it and if it is not AdLM then it is stepping on
    our registered port.
    jerry
    "jerry milana" wrote in message
    news:ef281d4.1@WebX.SaUCah8kaAW...
    > Harald,
    2000
    > AutoCAD clients.
    to
    did
    switch
    > Jerry Milana,
    > > 00.html
    > > Sincerely,
    > > Shaan Hurley
    > attempted
    > > normalt admitted
    > network
