• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Anderson, Kenneth
    AdLM not working in A2K?
    105 Views, 10 Replies
    01-06-2000 12:12 PM
    3 days now, and my dealer has yet to call me back.
    AdLM on NT 4sp3 server with
    A2K 2 seat lisc.
    using static IP addresses on all clients and servers.
    Single server image used for Client deployment installation used on both
    NT 4 sp3 workstation and a 95 client
    TCP/IP protocol
    ACADSERVER environmental variable set on clients and server (probably dont
    need it on the server)
    pinged server host name and clients name OK from both ends. (and addresses
    as well)
    A2K installs and starts on clients fine, but doesn't seem to obtain
    liscencing info,
    The clients bring up the Authorization Wizard on A2K startup, and of course
    the AdLM on the server doesn't report any use of the 2 lisc.
    My question is:
    Does the AdLM need to be installed on a server drive that can be accessed
    by the clients? It shouldn't matter right.
    I installed it on C: on the server, but this partition cannot be accessed
    on the network by the clients. Does this matter? I would think not. (of
    course the installation image on the server is on a different partition so
    that the clients can see and use it)
    Also, it is only the TCP/IP protocol from Control Panel/Network/protocols
    that must be installed for MS Networking, not the simple TCP/IP services, I
    dont need the client programs for simple TCP/IP services from the Control
    panel/Network/services installed on the clients or server. Isn't that
    correct?
    I know that the AdLM does not need to be installed on the client.
    so what is next? what am I missing here?
    is there some setting that tells AutoCAD that it needs to look for
    do they need to be in the same domain, no, that is an MS networking thing?
    I am pretty sure that they are all on the same subnet?
    I would check that by looking at Control Panel/Network/protocols/TCP/IP
    Protocol/IP Address/Subnet Mask,
    and making sure that those numbers match.
    255.255.255.0 on all machines...
    Correct?
    On the 95 client, does the primary network logon need to be set to
    something other than Novell IntranetWare Client? (I dont believe that
    there is a setting for this in NT) You see, we are actually a Novell shop
    here, but I have my own NT server set up for the CAD department. That
    wouldn't matter, would it? I dont use the Novell client32 on some of my NT
    workstations, only the Microsoft support for network clients, but that
    doesn't matter cause we are talking tcp/ip here, right? I dont want to use
    the IPX stuff, cause I cannot manage it, Our IT department wont give me
    Admin privileges, and I hate the scripts that they run, so I have to do my
    own thing and avoid IPX as much as I can. So, I have no privileges for the
    Novell side! I network administer my CAD stuff only from the NT world.
    Even my plotters are setup for tcp/ip printing. I try to stay as far away
    from Novell as I can, I only use it for file and print services on devices
    that they wont let me manage.
    I have wasted hours on this, my dealer has never dealt with the AdLM (it is
    no wonder that they haven't called me back) I never rely on them anyway,
    they are only sales people!
    What can I try next?
    I am stuck. I have been through the installation guide over and over,
    searched AutoDESK Technical Solutions, and have no where else to turn.
    Help please
    this is my last resort before having to deal with a dealer acting as a
    middleman, that knows very little about networking or AutoCAD for that
    matter. I have some questions, and I am not willing to get answers from
    someone that doesn't know what they are talking about.
    signed
    desperate
    K.
    Please use plain text.
    *Primary
    Re: AdLM not working in A2K?
    01-06-2000 03:05 PM in reply to: *Anderson, Kenneth
    So the service that the clients call for is active across tcp/ip
    There are several adlm admin tools to check this in the adlm directory but
    you suggest they can not be run from a client machine !!
    Then on a clients behest the license file is modified to show a token is
    released OOps you say they have no access to that drive !!
    AS SYSTEM ADMINISTRATOR INSTALL THE ADLM IN A DIRECTORY THAT THE WORLD CAN
    SEE
    Once its working you can shoot your foot by restricting the rights
    progressivly
    HTH
    sorry about the terseness its your dealer that I should direct my flu
    symptoms at
    "Kenneth Anderson" wrote in message
    news:01bf5882$670e5ad0$08844f98@fdc_bond...
    > A2K 2 seat lisc.
    > TCP/IP protocol
    > as well)
    > liscencing info,
    course
    > My question is:
    I
    > correct?
    > Correct?
    NT
    use
    the
    is
    > Help please
    > signed
    > desperate
    > K.
    *Anderson, Kenneth
    Re:
    01-06-2000 03:20 PM in reply to: *Anderson, Kenneth
    << AS SYSTEM ADMINISTRATOR INSTALL THE ADLM IN A DIRECTORY THAT THE WORLD
    CAN SEE>>
    Would this be a common sense thing? I only thought that it would be a good
    idea to put it in a place where people cant mess with it.
    It is interesting how the installation guide fails to mention that this
    might be a good idea. I do recall the guide (after reading it SEVERAL
    times) mentioning it in respect to the Client deployment installation image
    (that would be common sense to me), but not in regards to the AdLM. Since
    most servers that I have worked on have restrictions on the c: drive where
    the OS is installed, it should be noted somewhere that the AdLM should also
    be installed in a location that the client can see it.
    No need to reply. thanks for the response. hope that you feel better.
    P.S. I will assume that I dont need a new server code... (thank goodness,
    Ive never dealt with numbers of this magnitude before!! my V.I.N. is not
    that long, but at least I dont have to deal with the hardware lock key!)
    K.
    *Mann, Byron
    01-07-2000 07:57 AM in reply to: *Anderson, Kenneth
    You don't have a dial up connection on the server? RAS isn't recommended
    because it can change the IP address the LM reads.
    Other than that make sure the service is running under the system account.
    Also is the service running? I had a machine one time that refused to start
    the ADLM automatically on reboot.
    Good Luck,
    Byron Mann
    GIS Applications Engineer
    byron.mann@cadapult.net
    http://gis.cadapult.net/mapguide
    Kenneth Anderson wrote in message
    > A2K 2 seat lisc.
    > TCP/IP protocol
    > as well)
    > liscencing info,
    course
    > My question is:
    I
    > correct?
    > Correct?
    NT
    use
    the
    is
    > Help please
    > signed
    > desperate
    > K.
    *Burgasser, Drew
    01-07-2000 08:51 AM in reply to: *Anderson, Kenneth
    How do you go about installing A2K on the clients. Did you create
    deployment locations on the server and install from these deployment
    locations?
    It almost sounds like you have stand-alone installs of A2k. Did you run
    setup.exe from the root of the A2k cd on each client station? I hope not.
    You should never be prompted for an authorization code at the client station
    with the network version.
    When choosing a dealer, it's a good idea to choose a dealer that is an
    "Authorized Systems Center." Also, interview your dealer. Are they
    familiar with the network version of AutoCAD? Do they know what TCP/IP is?
    etc.
    Good luck,
    Drew Burgasser
    CAD Masters, Inc.
    www.cadmasters.com
    Autodesk Authorized Systems Center
    > A2K 2 seat lisc.
    > TCP/IP protocol
    > as well)
    > liscencing info,
    course
    > My question is:
    I
    > correct?
    > Correct?
    NT
    use
    the
    is
    > Help please
    > signed
    > desperate
    > K.
    *Anderson, Kenneth
    Re:
    01-07-2000 10:03 AM in reply to: *Anderson, Kenneth
    deployment locations?>>
    Yes
    station?>>
    No, setup was run on the client from setup.exe that was created on the
    server by running the Network Setup Wizard using the Client and Autodesk
    License Manager Installation selection.
    station with the network version>>
    MY FEELING EXACTLY!!!
    Why would the Auth. code wizard EVER come up on the clients when AutoCAD
    was installed from the server image used for Client deployment
    installation? It just doesn't make sense. I was wondering about that from
    the beginning, when I first installed the clients!
    Did my dealer or AutoDESK screw up and send me the wrong package?
    They sent me the license pack for the second seat. (just a piece of
    cardboard with a piece of paper and a bunch of numbers on it)
    I thought that it used to be that the CD said Networked Version on it.
    Is there a difference between the stand alone version and the networked
    version installation CD?
    I was kinda wondering bout that.
    I will be VERY upset if this is the case. I have spent 4+ hours now trying
    to determine what the problem is.
    < "Authorized Systems Center.">>
    I thought that there was not much choice here. Dont I have to use a dealer
    within a certain radius? And besides, I purchase Academic versions. So, I
    am fairly limited in who I can choose as a dealer. Besides, I have never
    run into a problem that I could not fix myself, with a little help from
    newsgroups, or Knowledge Base, etc... EXCEPT THIS ONE! I have never
    really needed the services of my dealer.
    I have very little hair left now.
    *Burgasser, Drew
    Re:
    01-07-2000 11:23 AM in reply to: *Anderson, Kenneth
    The A2k cd contains both the stand-alone and network installation. The
    stand-alone version is installed using the setup.exe in the root of the cd,
    and the network version is installed using the setup.exe in the netsetup
    folder.
    Does your adlm.log file contain any useful information with regard to
    clients trying to get a license?
    Does the nwclient.log show that the installations were completed?
    I would also try the process over again. Uninstall AutoCAD from the client
    stations, delete the client deployment locations, recreate them (leave the
    adlm as is - "Install Autodesk license manager files later"), and reinstall
    autocad from the deployment locations.
    We are in your geographical area, but you are correct that only certain
    dealers can sell academic versions. I don't know why.
    Drew Burgasser
    CAD Masters, Inc.
    news:01bf5939$77ecd180$08844f98@fdc_bond...
    > Yes
    > station?>>
    from
    trying
    > < > "Authorized Systems Center.">>
    dealer
    I
    *Anderson, Kenneth
    Re:
    01-07-2000 02:20 PM in reply to: *Anderson, Kenneth
    clients trying to get a license?>>
    No, it is empty.
    well, not exactly this is the files contents from last night when I tried
    to reinstall everything.
    Date Start Finish Len User/Status message
    01/06/00 18:19:41 18:19:41 0sec docman@FDC_VELLUM Client launched
    non-silent mode.
    01/06/00 18:21:31 18:21:31 0sec ANDERSON@FDC_VELLUM Client launched
    non-silent mode.
    client stations, delete the client deployment locations, recreate them
    (leave the adlm as is - "Install Autodesk license manager files later"),
    and reinstall autocad from the deployment locations.>>
    That is what I did last night, BUT, I did not delete the client deployment
    locations, I only reinstalled the client deployment files on the server
    OVER the originals. I was afraid that I might fowl up somthing, and since
    there was no un-install for the client deployment files on the server,
    well... . I will try again, but not till I hear from my dealer, I cannot
    affort to spend time on this much longer. My time must be billed to
    projects, and I dont know where I will even apply the time that I have
    spent so far!!!
    I.E. I give up!
    K.
    *Anderson, Kenneth
    Re:
    01-07-2000 02:23 PM in reply to: *Anderson, Kenneth
    < because it can change the IP address the LM reads.>>
    RAS is installed and running, but no one uses it. I have stopped it using
    the RAS Server manager. should I un-install it?
    account.Also is the service running?>>
    I see it there listed as running.
    *Milana, Jerry
    Re:
    01-07-2000 04:52 PM in reply to: *Anderson, Kenneth
    If you get prompted to authorize the AutoCAD session, you did not install the
    proper AutoCAD! Rebuild your deployment.
    Jerry Milana,
    Autodesk Product Support
    > No, it is empty.
    > non-silent mode.
    > non-silent mode.
    > spent so far!!!
    > I.E. I give up!
    > K.
