• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    z26j487
    Activation
    159 Views, 6 Replies
    02-06-2012 05:58 PM
    I have my product downloaded but am unable to activate it. I have tried everything that the autocad help area has on their hompage but nothing works. Any ideas?
    bjo
    New Member
    Re: Activation
    02-07-2012 01:38 AM in reply to: z26j487
    Try this link: http://usa.autodesk.com/support/installation/
    It's important to know if you have a singel license or a network license. Different ways to activate these.
    Kr
    Bjorn J.
    Kind regards
    Bjorn J.
    ****Sage
    Re: Activation
    02-07-2012 04:42 AM in reply to: z26j487
    You have not supplied any information here about what problem you are having with activation.
    Be specific.
    Include screen shots if appropriate.
    Exactly what step are you getting stuck on?
    You say it is downloaded -- but you never state if you extracted and installed the program.
    Is it installed and running normally in 30-day trial mode?
    Is this a student license?
    More information is needed.
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Member
    z26j487
    Re: Activation
    02-07-2012 11:26 AM in reply to: z26j487
    I have the program downloaded and running with the 30 day trial. The problem is when i open the program, Autocad 2011, i have the option of try or activate. I click activate and get a blank screen that pops up with what looks like two check boxes but there is no writing. This is where the problem is, i am trying to run it as a student also if that is helpful.
    **Master
    Patchy
    Re: Activation
    02-07-2012 11:40 AM in reply to: z26j487
    Member
    z26j487
    Re: Activation
    02-07-2012 01:13 PM in reply to: Patchy
    i've tried those and none of them work, I have no idea where to go from here
    ***Guru
    TravisNave
    Re: Activation
    02-08-2012 07:33 AM in reply to: z26j487
    Additional discussion about this issue can be found here:
    http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
