• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    HenrykBatko7483
    Activation error
    498 Views, 5 Replies
    05-06-2011 03:28 AM
    I'm trying to activate Autodesk Education Suite for Entertainment Creation 2011 - i received an activation code from Autodesk Authorization Center. But when I type this code into "Autodesk Licensing - Activation Options" window, MS Windows is showing error message "Program Autodesk component has stopped working.". I have 20 licenses (2 packages of 10 licenses) and 20 identicial computers with MS Windows 7 Pro 64 bit, 18 computers show this error.
    Product Support
    Re: Activation error
    05-09-2011 01:43 PM in reply to: HenrykBatko7483
    Check what component that it is calling.  Typically, you can see the .dll that is causing the problem.   For example, I have seen a conflict with the Wacom Bamboo driver.  Once, I uninstalled it, licensing worked again.
    Can you register it online 'auto-magically''?
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    New Member
    dowi84
    01-18-2012 10:32 AM in reply to: HenrykBatko7483
    i have the same problem and i check the dll causing the problem and it is:
    Faulting application name: LMU.exe, version: 4.0.35.0, time stamp: 0x4d06d384
    Faulting module name: adlmact_libFNP.dll, version: 11.9.0.0, time stamp: 0x4c1b5b55
    Exception code: 0xc000000d
    Fault offset: 0x0000000000193ba1
    Faulting process id: 0xd384
    Faulting application start time: 0x01ccd609d3b2994e
    Faulting application path: C:\Program Files\Common Files\Autodesk Shared\Adlm\R4\LMU.exe
    Faulting module path: C:\Program Files\Common Files\Autodesk Shared\Adlm\R4\adlmact_libFNP.dll
    Report Id: 2ce93402-41fd-11e1-887a-3c075410a4cf
    any idea please?
    New Member
    toddna
    01-28-2012 02:40 PM in reply to: HenrykBatko7483
    I'm having a similar issue but with the 2012 suite.  I've tried everything I can find for the past 3 weeks and can't resolve this issue.  It's a pity Autodesk doesn't have a solution.
    Product Support
    01-31-2012 11:39 AM in reply to: HenrykBatko7483
    If LMU crashes out, the only solution that I can suggest is to uinstall the software, reboot and then reinstall the software.  You may need to also delete the .data file. The location of the .data file is noted in this post:
    http://upandready.typepad.com/up_and_ready/2011/10/autocad-family-edu-and-commercial.html
    If LMU doesn't run, there will be no way to run the product as this is used to activate the product.  The last solution is to re-install the operating system.  This is a very tough suggestion but I would use it as a last resort.
    David Lau
    New Member
    dowi84
    02-02-2012 10:17 AM in reply to: HenrykBatko7483
    thanks!
    deleting the .data files solved the problem!!
    :smileyhappy:
