I am trying to activate Inventor 2008 Professional running on Windows 7 SP1 but it crashes with the following error report (sorry for German Windows version...):
Problemsignatur:
Problemereignisname: APPCRASH
Anwendungsname: Inventor.exe
Anwendungsversion: 12.3.0.34200
Anwendungszeitstempel: 483c7509
Fehlermodulname: mshtml.dll
Fehlermodulversion: 11.0.9600.17207
Fehlermodulzeitstempel: 53a22b71
Ausnahmecode: c0000005
Ausnahmeoffset: 000a6ed0
Betriebsystemversion: 6.1.7601.2.1.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: 5dec
Zusatzinformation 2: 5decad5e8cb84316c7c7ee04faeb46aa
Zusatzinformation 3: d2d1
Zusatzinformation 4: d2d12cd90c75c9fa2cc5c9acc0f93a6e
The 30-day trial version starts without any problems. Trying to activate via the "help" menu in the trial version also fails, but without an error message.
I also tried to run Inventor in XP and Vista compatibility mode but got the same error.
Someone knows how to fix this?
Best regards,
Sebastian
Solved by TravisNave. Go to Solution.
Autodesk 2008 products are not supported on Windows 7. The activation does not work properly. You *might* be able to get it to work, but there are no supported methods. You can try to search for solutions though. Good Luck!
