Installation & Licensing
Customer Service
joane.bonghanoy
Message 11 of 23 (620 Views)
Re: Activation code for Autocad 2007
10-28-2012 07:48 PM in reply to: lola_m92
Hi lola_m92,
Please Private Message me (click on my joane.bonghanoy profile name and then “Send this user a private message”) your Serial Number and Request Code.
Joane Bonghanoy
New Member
Message 12 of 23 (554 Views)
11-27-2012 11:30 AM in reply to: joane.bonghanoy
Hello, My name is Jake Padgett. I am repairing a computer for someone who had win xp w/ autocad 2007 on it, the system crashed and i installed win 7 and reinstalled autocad 2007 have orignial serial - License ID -  and (acd2007enuregemail) file. when tried to activate didnt work.
Thanks for any help you can provide
Member
Message 13 of 23 (550 Views)
11-27-2012 12:32 PM in reply to: AshKior
After 2 on line registrations and a phone call to Autodesk for another I finally un-installed and re-installed it, after that it accepted the on line registration. Don't know what I did wrong on the 1st install. Good luck. ***** NOTICE: This communication may contain proprietary, privileged or other confidential information. If you are not the intended recipient, or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this email in error, and delete the copy you received. The information in this message is confidential and may be legally privileged. It is intended solely for the addressee. Access to this message by anyone else is unauthorized. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful. Please delete the message and immediately contact the sender if you have received this message in error.
New Member
Message 14 of 23 (412 Views)
06-12-2013 01:03 AM in reply to: rrhein
:mansad:i need activation code for my autocad 2007 , i have  the serial number and request code but i don't have the activation code .please i need it , my serial number is xxx-xxxxxxxxx. THANKS
camilo.lemos
Message 15 of 23 (408 Views)
06-12-2013 01:32 AM in reply to: jeffery0147
Hi jeffrey0147,
I have edited your message to remove sensitive information.
The serial number you posted here is not a valid serial number issued by Autodesk. May I ask where this serial number was obtained?
Thank you
Camilo Lemos
Active Member
Message 16 of 23 (386 Views)
06-30-2013 11:47 PM in reply to: camilo.lemos
Hi!
I also have troubles with licensing the AutoCad 2007 on one of the user's computer.
I upgraded computer from XP to Win 7, and before that I exported the licesce to the same computer with activation code. Now the activation code is different, and I can't import license.
I have request code and serial, can somebody please generate activation code for me?
Thank you,
Regards
camilo.lemos
Message 17 of 23 (381 Views)
07-01-2013 12:38 AM in reply to: UrosO
Hi UrosO,
Please, send me the request code and serial number via Private Message for the activation (click on my camilo.lemos profile name and then on Send This User a Private Message).
Note that AutoCAD 2007 is not supported on Windows 7 so you will have to use the XP compatibility mode.
Best regards,
Camilo Lemos
Active Member
Message 18 of 23 (379 Views)
07-01-2013 12:47 AM in reply to: camilo.lemos
Hi!
Thank you for your help, but I already solved this problem with your staff through private messages.
And we don't have any problems with Autocad 2007 on Win 7, we just need to install the service pack 2.
New Member
Message 19 of 23 (370 Views)
07-01-2013 02:29 AM in reply to: UrosO
I'm trying to reinstall AutocadLT 2012 on my computer after the hard drive was reformatted from Windows XP to Windows. How should I proceed ?
New Member
Message 20 of 23 (356 Views)
07-02-2013 09:23 AM in reply to: pdeke
Not sure my previous message is posted at the right place...
Please note to clarify my request for help:
- My computer was upgraded from Windows XP to Windows 7;
- I try now to reinstall AutocadLT 2012 using my Autodesk CD disk;
- When the installation is aborted I receive the following message : 2013/7/2:18:03:33    pdeke    DEADK102500Y1    Installing .NET Framework Runtime 4.0: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/7/2:18:04:12    pdeke    DEADK102500Y1    Install    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1603.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
