• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Activation Wizard doesn't appear on startup.
    376 Views, 4 Replies
    11-04-2012 11:30 AM
    I installed Revit Arch 2013 and requested an activation key  which I have since received by email.  But when I start Revit, the Activation Wizard doesn't appear so I can't enter the activation key.  Any ideas on how I can enter the activation info?
    Les
    Please use plain text.
    Customer Service
    arlinpega.bibat
    Re: Activation Wizard doesn't appear on startup.
    11-04-2012 09:03 PM in reply to: LesWoolsey
    Hi LesWoolsey:
    Here are some helpful information on how to activate your serial number:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17971157&linkID=9240617
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18513720&linkID=9240617
    For activation issue, please contact our Registration and Activation Team directly for assistance or call them at the following numbers:
    Americas: (800) 551-1490
    Europe / Middle East / Africa: 65.6735.5688
    Asia / Pacific: 41.32.723.9595
    I hope this helps.
    Best Regards,
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Product Support
    aaronhai
    11-04-2012 09:11 PM in reply to: LesWoolsey
    Hi LesWoolsey,
    If you only have single product installed in your machine, please delete the Licensing info (adsk*.data file) to force re-activation.
    To delete the licensing info, please backup and remove these files:
    On Vista or Windows 7
    C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
    C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data.?backup
    On Windows XP
    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data.backup
    Please let me know if that works.
    Thank you.
    Aaron Hai
    AutodeskCare | Product Support
    TW | PI | YT | BLOG
    If my reply was helpful, please Kudo or Accept as Solution. :smileyhappy:
    Member
    11-05-2012 02:53 PM in reply to: aaronhai
    After moving those files out of the way and starting Revit, I was asked about joining the quality feedback program and then Revit continued.  I saw a small Window shich said it was checking the licensing but then that box disappeared and  I did not get the activation wizard.
    Member
    11-05-2012 02:54 PM in reply to: arlinpega.bibat
    I had already gone through  those pages and they offered no useful information regarding this problem.
