• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    zankrep
    Activation Issues
    1954 Views, 4 Replies
    01-01-2011 09:03 AM
    Hey all,
    I while back I bought the Autodesk Education Suite for Entertainment Creation 2011. I installed the Maya 2011 from this onto my mac. I then upgraded and got Autodesk Maya 2011 Student version to Commercial. Again Had no issues installing and activating.
    The problem is that I am wanting to learn 3DS Max and other programs that came in the Entertainment Creation Suite. Since I have taken it off my Mac and want to install it onto my Laptop (Windows) I feel that this would then be classed as my main computer for the Autodesk Education Suite. SO the problem at hand is that I can not activate it. I assume this is because I activated it on the Mac. Is there a way of puting 3DS Max etc onto my laptop? Any help would be great as I did not know where to get help from.
    My other thought is since half of the programs in the Autodesk Education Suite will not work on a mac surely you have to be able to put at least those onto a pc? Hence my confusion?
    Thank you for any help given. I don't quite know what to do as I am now stuck.
    ****Sage
    Re: Activation Issues
    01-01-2011 09:34 AM in reply to: zankrep
    You never state what error you are getting on attempting to activate - you can activate on two machines.
    Students can get Autodesk software for FREE from http://www.autodesk.com/edcommunity
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Member
    zankrep
    01-01-2011 09:55 AM in reply to: zankrep
    Sorry for not putting the error code. I get a nice variaty. Here are the error code I get.
    Thank you for purchasing an Autodesk product.
    The next pages will guide you through registration and activation of your product.
    If you need help with a field, click the help icon
    Enter Product Serial Number.Help
    The serial number you entered is not valid. Try again. (1)
    This is the one I get when trying to activate it with the serial number. I get this after clicking  Connect now to activate.
    If I click <script type="text/javascript">// document.writeln(xmsgRegAuthInfo4A); // </script>   'I have an act... and enter the number that I had from when i last activated it.
    I get this responce
    Registration-Activation Error (0015.111)
    <script type="text/javascript">// if(rterrnum.substring(0,4)=="0012") document.writeln(xmsgRegErrorFlex); else { switch (rterrnum) { case "-1": case "-5": document.writeln(xmsgRegErrorAuth); break; default: document.writeln(xmsgRegErrorAuthEntry); break; } } // </script> There is a problem with the activation code that you entered. Click one of the following links.
    So I don't know what i am doing wrong. Does this help?
    New Member
    girishismail
    02-08-2012 03:48 AM in reply to: zankrep
    < Registration-Activation Error (0015.111)
     why  pls reply? wht r  i do?
    Customer Service
    camilo.lemos
    02-08-2012 06:39 AM in reply to: girishismail
    Hi girishismail.
    Can you please send me your serial number via private message (click on that envelope next to your user name up there) so I can have a look at that error?
    Thanks!
    Camilo Lemos
    AutodeskCare | Community Manager
    TW | PI | BLOG
