Installation & Licensing
Activation Failed message
5 REPLIES 5
1538 Views, 5 Replies
I just downloaded 3DS max 2012 stdent versioneverything installed fine the seriel and product key works just fine up untill I try to launch and activate my product. I get the message saying I must activate my product so I click "activate, I go and agree to the terms and conditions and press continue, at this point I get an error message saying "Product activation error. Error code 110" I have tried everything under the sun to get the product to activate. I reinstalled the product after I purged my system of every last trace of it (even my registry) and I am still getting that message. any help on this issure would be appreciated.
Thank you.
5 REPLIES 5
arlinpega.bibat
Hi hodgi920:
My apologies for the inconvenience. You  may check the thread on this link:http://forums.autodesk.com/t5/Installation-Licensing/Licensing-Error-Code-110-AutoCAD-and-Civil-3D-2... to resolve the error you are getting.
Best Regards,
Arlin Bibat
in reply to: arlinpega.bibat
Hello!
I've got the same problem.
I'm a student, so I registered at autodesk.com and downloaded 3ds max 2010 then installed it. But when I try to activate it, it inevitably says error 110 and shutting down error 20.
No chance for "request code".
And:
1.      ASR folder was created during the install.
2.     ASR files are in ASR folder.
Please help me.
Regards, Eva.
camilo.lemos
Hi Eva,
Have you tried uninstalling and re-installing the product as mentioned on this thread?
Please, follow our re-installation guide to make sure all necessary files have been removed and re-installed.
Camilo Lemos
in reply to: camilo.lemos
Hello! Thank you! The thorough instruction has helped, now program is running! Regards, Eva.
jerome.pineau
Great news Eva! If you have a minute, could you click the Accept as Solution button down below? This will help other folks quickly locate this solution when searching through the forums.
Yours,
J.
Jerome Pineau
AutodeskHelp | Social Media Strategist
twitter.com/AutodeskHelp
jerome.pineau@autodesk.com
Administrator Productivity
