• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Activation Error
    82 Views, 1 Replies
    09-25-2012 07:02 PM
    I using AutoCAD 2008 LT for couple years. But last weekmy hard drive failed, I did a hard drive replacement & reinstall the whole system. Now I facing problem when I need to activate my AutoCAD.
    i request for activation code from autodesk, they send my the ActivationCode。 But the Request Code is different with my AutoCAD application gives to me.
    So the Request Code & Activation Code are not patch. I cant activate it.
    I  NEED HELP ~~~!!!
    Serial number: xxx-xxxxxxxxx
    Old Request Code : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    How do I enter the new request code?
    Please use plain text.
    Customer Service
    arlinpega.bibat
    Re: Activation Error
    09-25-2012 07:19 PM in reply to: calvinlim
    Hi calvinlim:
    I sent you your activation code through private message. Fofr future reference, you may directly contact our Registration and Activation Team should you encounter any similar issue.
    Also, make sure not provide any sensitive information like serial number with request code through public forums. I have removed these information from your original message.:smileyhappy:
    Let me know if you have any further questions.
    Best Regards,
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
