Installation & Licensing
Activating Autodesk 3ds Max 2014 in closed network
2 REPLIES 2
521 Views, 2 Replies
I am trying to install 3ds Max 2014 on a computer in a closed network which has no internet connection.  Since it is a closed network, I have to copy the files to a Double Density DVD, then bring it into the closed network.  When I try install the program from the disk, it gets about halfway through then asks for me to insert the disc (the DVD is already in the computer).  What is going on?  We acquired the program through download from Autodesk, therefore I do not have an official install disc.  Any suggestions?
Brian
2 REPLIES 2
TravisNave
Yes.  Copy the media to the hard drive.
Did you properly extract then combine all the files and folders, overwriting when prompted?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
I did try to transfer the files from the disc to the computer but received
some errors. I think the issue is that the media was burned to a double
density disc but the computer I am trying to install on does not have a
compatible DVD player, therefore it is only reading the initial layer and
prompting for another disc. I have taken my compatible external dvd player
into the closed network and will attempt the install again. I am waiting
for the graphic artist to go home for the day to try this.
Administrator Productivity
