Installation & Licensing
Activating Autocad LT 13 on Vista - Request Code
2 REPLIES 2
whiteferg
480 Views, 2 Replies
Cannot access a Request Code after installing program.  Two options given to find it, don't work - is it because I have Windows Vista???????? Have an Activation Code - does this mean a Request Code has been given - but how do I get it?
2 REPLIES 2
pendean
in reply to: whiteferg
TravisNave
Because of the lack of support for Vista, activation issues are often the biggest problem.  Your best bet is to disable UAC and Run As... Administrator.  You might have luck changing the compatibility mode to Windows XP3.
Otherwise, you will have to install on Windows XP or Windows 7.  Sorry.
Autodesk Forums:
Administrator Productivity
