Installation & Licensing
Accessing ADLM on a different domain?
2 REPLIES 2
mhaneyit
208 Views, 2 Replies
Can you access an ADLM that is on a different domain than the one your computer is connected to?
Thanks in advance,
Derek
2 REPLIES 2
TravisNave
in reply to: mhaneyit
Yes.
As long as you can ping the machine name, you shouldn't have any problems.
Autodesk Forums:
Yes it runs over tcp/ip. In many ways it works similar to a webserver as far
as technology goes.
I'm sure you never asked if your webserver will work in a different domain
because it's common knowledge that it will.
Best regards,
Henrik Goldman
Flexlm license management to reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Knowledgebase on software license management - http://kb.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
Administrator Productivity
