Hi
I have an acad.lsp file I have used for years and now it will not load with Civil3d 2012
searched paths added Civil3d is finding it when you use (command"notepad"(findfile"acad.lsp"))
at the command line added to startup suite still does not bring in the functions
Any ideas. Our staff are losing productivity without this commands
Regards
Justin Ralston
Solved by ralstogj. Go to Solution.
found the issue one search path not loaded used the steps outlines here
http://lee-mac.com/autoloading.htmland the load command to check what was not loading
