Installation & Licensing
Member
Message 1 of 6 (953 Views)
AUtodesk 3ds Max & Maya Installation Error
953 Views, 5 Replies
04-15-2013 09:14 AM
I've just downloaded the Trial straight from the sight. And once it was done downloading I open it, install it. But once it gets to this step, all i get is this message, and I have no idea what to do. Any help would be greatly appreciated...
Also, I've done some reading about the system requirements for certain programs, Maya and 3ds Max use Windows 7 Professional, I have Windows 7 Ultimate. Would the problem be my operating system?
Error
TravisNave
Message 2 of 6 (948 Views)
Re: AUtodesk 3ds Max & Maya Installation Error
04-15-2013 09:23 AM in reply to: jrn0505
Try installing as a different user with local admin rights and no spaces in the username.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
Message 3 of 6 (934 Views)
04-15-2013 10:26 AM in reply to: TravisNave
I'm downloading the trial again, I'll see if this works or not, thanks again. Never thought about making a new account.
Member
Message 4 of 6 (929 Views)
04-15-2013 10:53 AM in reply to: TravisNave
It didn't work. I made it through the error i usually get, but then it failed to install Maya and 3ds Max. Something about an error with Microsoft Visual C++ 2005 Redistributable.
TravisNave
Message 5 of 6 (913 Views)
04-15-2013 12:39 PM in reply to: jrn0505
Then uninstall that version from your machine and try again.
Member
Message 6 of 6 (898 Views)
04-16-2013 04:43 PM in reply to: TravisNave
I did. actually uninstalled all of the 2005 packs. one by one.
the log i get is.
2013/4/16:15:12:42 ⌐⌐ JON === Setup started on JON by ⌐⌐ ===
2013/4/16:15:12:42 ⌐⌐ JON Path_Length: 151
2013/4/16:15:12:42 ⌐⌐ JON Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2013/4/16:15:12:42 ⌐⌐ JON Launch
2013/4/16:15:12:42 ⌐⌐ JON CommandLine
2013/4/16:15:12:42 ⌐⌐ JON Current Directory C:\Users\⌐⌐\AppData\Local\Temp\_AID38.tmp
2013/4/16:15:12:45 ⌐⌐ JON === Setup ended ===
2013/4/16:15:12:43 ⌐⌐ JON === Setup started on JON by ⌐⌐ ===
2013/4/16:15:12:43 ⌐⌐ JON Path_Length: 151
2013/4/16:15:12:43 ⌐⌐ JON Current Directory C:\Users\⌐⌐\AppData\Local\Temp\_AID38.tmp
2013/4/16:15:12:43 ⌐⌐ JON Launch
2013/4/16:15:12:45 ⌐⌐ JON PageOpen LaunchDialog
2013/4/16:19:40:15 ⌐⌐ JON PageOpen LicenseDialog
2013/4/16:19:40:17 ⌐⌐ JON PageOpen ProductInfoDialog
2013/4/16:19:40:21 ⌐⌐ JON PageOpen ProductSelectionDialog2
2013/4/16:19:40:35 ⌐⌐ JON PageOpen FullProgressDialog
2013/4/16:19:40:35 ⌐⌐ JON Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\⌐⌐\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/4/16:19:40:38 ⌐⌐ JON Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
