ERROR LOG BELOW:
2012/12/3:04:18:54 God GOD-PC === Setup started on GOD-PC by God ===
2012/12/3:04:18:54 God GOD-PC Launch
2012/12/3:04:19:04 God GOD-PC === Setup ended ===
2012/12/3:04:18:56 God GOD-PC === Setup started on GOD-PC by God ===
2012/12/3:04:18:56 God GOD-PC Launch
2012/12/3:04:19:04 God GOD-PC PageOpen LaunchDialog
2012/12/3:04:19:10 God GOD-PC === Setup ended ===
2012/12/3:04:21:04 God GOD-PC === Setup started on GOD-PC by God ===
2012/12/3:04:21:04 God GOD-PC Launch
2012/12/3:04:21:10 God GOD-PC === Setup ended ===
2012/12/3:04:21:05 God GOD-PC === Setup started on GOD-PC by God ===
2012/12/3:04:21:05 God GOD-PC Launch
2012/12/3:04:21:10 God GOD-PC PageOpen LaunchDialog
2012/12/3:04:21:15 God GOD-PC PageOpen LicenseDialog
2012/12/3:04:21:18 God GOD-PC PageOpen ProductInfoDialog
2012/12/3:04:25:58 God GOD-PC PageOpen ProductSelectionDialog2
2012/12/3:04:26:13 God GOD-PC PageOpen FullProgressDialog
2012/12/3:04:26:13 God GOD-PC Installing DirectX Runtime: C:\Users\God\Desktop\archicard for architecture\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/3:04:27:00 God GOD-PC Install DirectX Runtime Succeeded
2012/12/3:04:27:00 God GOD-PC Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Users\God\Desktop\archicard for architecture\x64\en-us\ACA\ACA.mst;C:\Users\God\AppData\Local\Temp\_AIB117.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\God\Desktop\archicard for architecture\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:04:28:55 God GOD-PC Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603
2012/12/3:04:28:55 God GOD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Solved by asburyj. Go to Solution.
It's difficult to tell what is causing your install failure just from this log.Can you let us know if you are using an install media or did you download the installer? Also, do you have any other AutoCAD versions installed on your system?
sure. i downloaded autocad architecture 2013 straight from the autodesk website. plus the installation was attempted from the local drive.
i do have autocad 2013 installed....and it works.
Looking at the install log i see the faulting error is related to the ngen create action. To work around this error you will need to uninstall servicepack 1.1 from your AutoCAD and then try the ACA install again.
More details on this error can be found at the below link.
