Installation & Licensing
kzornoza
251 Views, 1 Reply
AM2011 64 activation
I've installed an AM2011 on a W7 64 in a trial mode with a 000 serial number. When I'm going to activate with a serial number, an error it showed. Moreover, the request code doesn't show in the register page. What is the problem? I have 15 days trial only.
Regards.
1 REPLY 1
TravisNave
in reply to: kzornoza
The serial number you are using is not valid.  This is likely due to the fact that either the Subscription on the product has expired and/or the product has been upgraded or crossgraded to another version.
You need to contact your Reseller.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
