Installation & Licensing
ADesl Factory Desgin Premium
3 REPLIES 3
butter2011
239 Views, 3 Replies
Is there a way to diable the cancel button during the installation of the suite, I tried qb-! andit does not work
On the uninstall, I used the Suite Uninstaller, is there a way to disable the cancel button as well and avoid the OK message at the end, basicaly i want it all to be silent with no user interaction and no OK message
Any helps is appreciated,
Butter
3 REPLIES 3
david.lau
in reply to: butter2011
If you create a deployment, there should be an option to check on 'silent'.
David Lau
butter2011
Yes, I did create the deployment option and it does install silently but cancel button still is not grey out.   Not sure how to disable the button.
TravisNave
Tell your users not to press 'Cancel.'
Autodesk Forums:
Administrator Productivity
