Installation & Licensing
ADT3.3 Deployment Problems
10 REPLIES 10
Message 1 of 11
190 Views, 10 Replies
OK, afeter several tries, and several reboots, and hte same errors coming up
again and again, I am tossing in the towe, and crying for help.
When I set up the network deployment image files, everythign appears to go
smoothly.
When I go to install on a client, I get an error that reads:
Error 1324. The Folder Path 'Program Files' contains an invalid character.
So, I went into the appsetup.inf, and changed the path to something that had
no blank spaces, and no parts of the path were longer than 8 characters
(what the heck, might as well make the path backwards compatible to DOS 1)
Then I try again, and get the same error, only this time, the problem path
is 'CD Manager.'
That pth is not spelled out in the appsetup.inf file. I did specify to
apply the CAD Manager Controls to Today, so I am expecting that to be the
problem. I'm about to create a whole new deployment location, with a fresh
new image, short path, no CAD Manager, etc. But even so, this is
ridiculous. Does anyone have a clue what has gone wrong?
10 REPLIES 10
Message 2 of 11
Charles -
I'd highly recommend a new deploy image. I've had some problems with appsetup.inf files
in the past and I've generally found that it's been easier just to create a new deploy
than it is to try to fix and existing deploy that has never worked. If the appsetup.inf
got hosed somehow, it's fairly likely to assume that other stuff was also "broken" during
the deployment image creation. Was it heat near the server, solar flares, ozone depletion
who knows. Try creating the deploy again and let us know if that doesn't work (just
delete the old one, it's not doing any good anyway).
hth
jason martin
frankfurt-short-bruza
"Charles Prettyman" wrote in message
news:420B617AF0EAF0B44FCF7C968B0CC2C9@in.WebX.maYIadrTaRb...
> smoothly.
> is 'CD Manager.'
Message 3 of 11
I just did create a whole new deploy image, on a different drive. I used a
very simple path for hte program installation (D:\ADT33\)
and I did not apply the CAD manager controls to today.
Error 1324. The Folder Path 'CAD Manager' contains an invalid character.
reared its ugly head again!
I don't think it's even actually the Appsetup.inf. I was able to compare it
to one that worked for someone (Thanks for that Jason), and there are no
differences other than obvious stuff (who it's licensed to, server, ID, etc)
My next step is to set up all over again on a different machine. Even if I
eventually have to migrate people back to the server I've been trying (it's
a load balancing issue, but there may be other solutions to that)
"jason martin" wrote in message
news:9EA3148944E0B507446531C14A72DE8A@in.WebX.maYIadrTaRb...
> Charles -
appsetup.inf files
a new deploy
the appsetup.inf
"broken" during
ozone depletion
work (just
> hth
> jason martin
coming up
go
> > smoothly.
character.
had
1)
path
> > is 'CD Manager.'
the
fresh
Message 4 of 11
Also, I've noticed that when you go to create new image files, the server
remembers a lot of what you did last time. So, if there is some hidden
invalid character in those paths, as a result of some sector of my disk
getting fried, it may be getting that bad character out of local memory.
Do you know where it stores that info? Should I find that, and wipe it out,
and force it to make a clean start?
news:1BCC46BBAEE7EBC0109975FE408479F2@in.WebX.maYIadrTaRb...
a
it
etc)
I
(it's
> > Charles -
> appsetup.inf files
create
> a new deploy
> the appsetup.inf
also
> "broken" during
flares,
> ozone depletion
doesn't
> work (just
> > hth
> > jason martin
> coming up
to
> go
> > > smoothly.
> character.
that
> had
characters
DOS
> 1)
> path
> > > is 'CD Manager.'
to
> the
> fresh
Message 5 of 11
OK, a whole new image file on a different machine (although it was pointed
to the same ADLM) brought up the same freaking errors.
So, two things occur to me:
1. The CD has a scratch, or fingerprint on it that repeatedly casues the
same error (unlikely, but a lot of things that actuallyhappen defy all
reason)
or
2. The first failed install, for whatever reason, left some garbage behind
on the workstation that is getting in the way of all these new installation
attempts. (I'd say that this is more likely, but what do I know)
> Charles -
appsetup.inf files
a new deploy
the appsetup.inf
"broken" during
ozone depletion
work (just
> hth
> jason martin
coming up
go
> > smoothly.
character.
had
1)
path
> > is 'CD Manager.'
the
fresh
Message 6 of 11
It continues
I had a chat with my reseller, and at his suggestion, I wiped out the
registry key for Autodesk, and rebooted, and that still didn't solve it.
For the time being I have ADT3.3 installed locally, so I can get some work
done. But I need to get this resolved.
news:C946F3A046A5E3A5B7D2BE7B0C46DE5E@in.WebX.maYIadrTaRb...
> reason)
> or
installation
> > Charles -
> appsetup.inf files
create
> a new deploy
> the appsetup.inf
also
> "broken" during
flares,
> ozone depletion
doesn't
> work (just
> > hth
> > jason martin
> coming up
to
> go
> > > smoothly.
> character.
that
> had
characters
DOS
> 1)
> path
> > > is 'CD Manager.'
to
> the
> fresh
Message 7 of 11
Charles - The 1324 error generally indicates that the path specified for 'Cad Manager'
contains a pointer to a drive that doesn't exist. The only thing that I can think of that
would cause it to error on 'Cad Manager' is the cad manager control of the autocad today
window. It could also be possible (although not likely) that there isn't enough temp space
on the C drive of the machine that you are trying to install to. This doesn't make any
sense at all but I've seen all kinds of problems that shouldn't occur when there isn't
enough space on C.
hth
jason
> > Charles -
> appsetup.inf files
> a new deploy
> the appsetup.inf
> "broken" during
> ozone depletion
> work (just
> > hth
> > jason martin
> coming up
> go
> > > smoothly.
> character.
> had
> 1)
> path
> > > is 'CD Manager.'
> the
> fresh
Message 8 of 11
Actually I don't think that the server remembers. I think that it is stored in the
registry of the workstation from which the image is being created.
jason
news:7E2628FABD922E94A40D887778C0E14F@in.WebX.maYIadrTaRb...
Message 9 of 11
That makes some sense. We have an ongoing problem with several of hte
workstations here that they came from the factory with undersizd C drives,
and a nice big D drive. Lacking a site license for partition magic, I have
been loathe to reformat the drives and start over, but enough hot fixes and
service packs, etc have come along that the C drives have slowly filled up,
and it's very hard to get them stripped all the way clean. I guess it's
time.
news:4AADA09E6F10D41C903DF98536DB95B7@in.WebX.maYIadrTaRb...
'Cad Manager'
can think of that
autocad today
enough temp space
doesn't make any
there isn't
> enough space on C.
> hth
> jason
used a
character.
compare it
etc)
if I
t's
> > > Charles -
> > appsetup.inf files
create
> > a new deploy
If
> > the appsetup.inf
also
> > "broken" during
flares,
> > ozone depletion
doesn't
> > work (just
> > > hth
> > > jason martin
> > coming up
to
> > go
> > > > smoothly.
> > character.
that
> > had
characters
DOS
> > 1)
problem
> > path
> > > > is 'CD Manager.'
to
be
> > the
a
> > fresh
Message 10 of 11
Thank you all for the various thoughts on this. For those who face
somethign similar, the actiuual problem turned out to be this:
Most machines inthe office have very little room to spare on C, but have
room of D. So I set up the istallation files to default to D for
installation. A few machines, however, including my own, have other issues.
In my case, D is a zip drive, and all the applications got on E (don't ask
me why, Dell set it up like that). So, althoughthe error messages were
refering to paths like "CAD Standards" or "Program Files" the actual error
was in the drive letter.
One of the frustrating parts of this is htat I had somewhat anticipated the
problem, and set up the installation NOT to be silent, so that I caould have
one set of image files to install to C, D or E as appropriate. But the
error cropped up before I was able to redirect this installation to E.
Now, on to the next challenge.
Message 11 of 11
BTW, it is my reseller who actually deserves any credit given for solving
this - Thank you Jan.
news:EB00435F41FCD94908D9280B17592DD1@in.WebX.maYIadrTaRb...
issues.
the
have
Administrator Productivity
