Also, I've noticed that when you go to create new image files, the server
remembers a lot of what you did last time. So, if there is some hidden
invalid character in those paths, as a result of some sector of my disk
getting fried, it may be getting that bad character out of local memory.
Do you know where it stores that info? Should I find that, and wipe it out,
and force it to make a clean start?
"Charles Prettyman" wrote in message
news:1BCC46BBAEE7EBC0109975FE408479F2@in.WebX.maYIadrTaRb...
> I just did create a whole new deploy image, on a different drive. I used
a
> very simple path for hte program installation (D:\ADT33\)
> and I did not apply the CAD manager controls to today.
> Error 1324. The Folder Path 'CAD Manager' contains an invalid character.
> reared its ugly head again!
> I don't think it's even actually the Appsetup.inf. I was able to compare
it
> to one that worked for someone (Thanks for that Jason), and there are no
> differences other than obvious stuff (who it's licensed to, server, ID,
etc)
> My next step is to set up all over again on a different machine. Even if
I
> eventually have to migrate people back to the server I've been trying
(it's
> a load balancing issue, but there may be other solutions to that)
> "jason martin" wrote in message
> news:9EA3148944E0B507446531C14A72DE8A@in.WebX.maYIadrTaRb...
> > Charles -
> > I'd highly recommend a new deploy image. I've had some problems with
> appsetup.inf files
> > in the past and I've generally found that it's been easier just to
create
> a new deploy
> > than it is to try to fix and existing deploy that has never worked. If
> the appsetup.inf
> > got hosed somehow, it's fairly likely to assume that other stuff was
also
> "broken" during
> > the deployment image creation. Was it heat near the server, solar
flares,
> ozone depletion
> > who knows. Try creating the deploy again and let us know if that
doesn't
> work (just
> > delete the old one, it's not doing any good anyway).
> > hth
> > jason martin
> > frankfurt-short-bruza
> > news:420B617AF0EAF0B44FCF7C968B0CC2C9@in.WebX.maYIadrTaRb...
> > > OK, afeter several tries, and several reboots, and hte same errors
> coming up
> > > again and again, I am tossing in the towe, and crying for help.
> > > When I set up the network deployment image files, everythign appears
to
> go
> > > smoothly.
> > > When I go to install on a client, I get an error that reads:
> > > Error 1324. The Folder Path 'Program Files' contains an invalid
> character.
> > > So, I went into the appsetup.inf, and changed the path to something
that
> had
> > > no blank spaces, and no parts of the path were longer than 8
characters
> > > (what the heck, might as well make the path backwards compatible to
DOS
> 1)
> > > Then I try again, and get the same error, only this time, the problem
> path
> > > is 'CD Manager.'
> > > That pth is not spelled out in the appsetup.inf file. I did specify
to
> > > apply the CAD Manager Controls to Today, so I am expecting that to be
> the
> > > problem. I'm about to create a whole new deployment location, with a
> fresh
> > > new image, short path, no CAD Manager, etc. But even so, this is
> > > ridiculous. Does anyone have a clue what has gone wrong?
