Installation & Licensing
*Bomboy, Paul
Message 1 of 5 (200 Views)
ADML on Service with 2 NICS
200 Views, 4 Replies
11-27-2001 03:05 AM
When I installed the ADLM using the licmgr program found the 1st NIC in
my server (this is a token ring card). I need to be to override the
value so my licmgr will funtion with the Ethernet card. My lic file
contains the MAC of the token ring card. What do I need to do to
correct this problem?
*Nehls, Kevin
Message 2 of 5 (200 Views)
Re: ADML on Service with 2 NICS
11-27-2001 05:07 AM in reply to: *Bomboy, Paul
First things first. Are you using AdLM or
FlexLM? They are 2 completely different
animals.
If you are using AdLM, you're out of luck as
you can't use it reliably on a multi-homed
machine, nor can it be used reliably on a
machine with a dynamic IP address.
If you are using FlexLM, I don't know the
answer. Hopefully someone else does.
hth
Kevin Nehls
"Paul Bomboy" wrote
in message
news:3C03E407.FAB8A456@prbcomputers.com...
*martin, jason
Message 3 of 5 (200 Views)
Re:
11-30-2001 03:39 PM in reply to: *Bomboy, Paul
Just a bit of a follow up on Kevin's answer.
He is extremely correct in stating that if you use the Pre-2k2 version of
the adlm (elan) won't (or shouldn't, reliably) work with a multi-homed
system. Now the post 2k2 adlm (FlexLM) will work on a multi homed system
and is only dependant on the ethernet addr of the network card that you want
to use for the adlm (this is good). What I usually do on a multi-homed
system is to ping the ip addr (since the FlexLM communicates over tcp/ip, it
should have an ip addr) from an NT based (NT, 2k, XP Pro, or anything that
can do an arp) client and after the ping type arp -a (since this involved
typing in a win system I'm assuming that you know I mean at the command
prompt. For more information see
http://www.fsb-ae.com/acadnetwork/acadnetworkfaq.htm#3c and scroll down a
bit) and you can get the ethernet address of the card that you just pinged.
hth
jason martin
frankfurt-short-bruza
Kevin Nehls wrote in message
news:EFDFF8FAD501419FAC11C91D458DCC31@in.WebX.maYIadrTaRb...
> animals.
> hth
> Kevin Nehls
> "Paul Bomboy" wrote
> in message
*Bomboy, Paul
Message 4 of 5 (200 Views)
FlexLM Service with 2 NICS
12-05-2001 03:00 AM in reply to: *Bomboy, Paul
The NIC has (2) IP Address. Can I use the IP address of the machine as the host
name with FlexLM instead of a physical machine name?
*martin, jason
Message 5 of 5 (200 Views)
12-05-2001 03:12 AM in reply to: *Bomboy, Paul
The globetrotter documentation says that you can, (in the license file, correct?) but why? Isn't the host name going to resolve to
that IP address anyway?
Just because the globetrotter documentation says that you can, doesn't really mean that you can. It means probably. Just because
globetrotter has it documented, that doesn't mean that autodesk has implemented it.
jason martin
"Paul Bomboy" wrote in message news:3C0E6ED6.DEAC7833@prbcomputers.com...
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
