Installation & Licensing
*Lynch, Ken
Message 1 of 11 (115 Views)
ADLM on Small Business Server
115 Views, 10 Replies
11-23-1999 10:32 AM
I recently installed AdLM for AutoCAD Map 3 on our Small Business Server
(WinNT 4.0 sp 4). I read a tech document (td154038.doc) that indicated that
I should be logged in local to the machine, not the NT domain. I don't have
that option. When I select the pull down in the Domain window at the login
screen I don't have any options. What can I do to get the networked PCs to
see the AdLM? Has anyone had this problem before? Everything else with the
install seems correct, but the clients can't get a license.
Ken Lynch
GIS Analyst
Keller Engineers, Inc
420 Allegheny Street
Hollidaysburg, PA 16648
(814)696-7430
*Milana, Jerry
Message 2 of 11 (115 Views)
Re: ADLM on Small Business Server
11-23-1999 05:15 PM in reply to: *Lynch, Ken
Ken,
First thing to do is look at your log file (adlm.log located in c:\adlm\log).
Look for authentication failures and attempts by clients to start Map. You are
likely to find an error message that will point you towards the problem.
Jerry Milana,
Autodesk Product Support
> Thanks,
> Ken Lynch
> GIS Analyst
> (814)696-7430
*Lynch, Ken
Message 3 of 11 (115 Views)
Re:
11-24-1999 06:53 AM in reply to: *Lynch, Ken
Attached you'll see the Adlm.log file. I can't see anything wrong, other
than there is no indication that the clients are trying to get a license
from the server.
99-Nov-23 14:18:56: Log file zeroed. Prior copy in C:\ADLM\LOG\ADLM.old.
99-Nov-23 14:18:56: Autodesk License Manager - Copyright 1997 Elan Computer
Group, Inc.
99-Nov-23 14:18:56: ADLM 5.0.1c started on kellerfs1 (00a0c9a791d3).
99-Nov-23 14:18:56: Vendor ID = 1a2ccac.
99-Nov-23 14:18:56: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
99-Nov-23 14:18:56: PID = 149.
99-Nov-23 14:18:56: Port = 1422.
99-Nov-23 14:18:56: Log file = C:\ADLM\LOG\ADLM.LOG.
99-Nov-23 14:18:56: Key path = C:\ADLM\KEY.
99-Nov-23 14:18:56: Keyaccept = 310.
99-Nov-23 14:18:56: Resource file = .
99-Nov-23 14:18:56: Message level = 3.
99-Nov-23 14:18:56: Max log file size = 65536 bytes.
99-Nov-23 14:18:56: Administra@kellerfs1 [1]: key C:\ADLM\KEY\171.lic 1
tokens [MINIKEY].
Jerry Milana wrote in message
news:383B3C48.276615FE@autodesk.com...
> Ken,
c:\adlm\log).
You are
> Jerry Milana,
that
have
login
to
the
> > Thanks,
> > Ken Lynch
> > GIS Analyst
> > (814)696-7430
*Allaire, Yves
Message 4 of 11 (115 Views)
11-25-1999 09:03 AM in reply to: *Lynch, Ken
To install ADLM Server you need to be local on the Server, or you can install
the Server on any machine but you need to note that this machine acts as the
ADLM Server.
To install the clients you need to have installed deployment files on the
server, that the clients use to install AutoCAD to their workstation.
Hope this helps.
> Thanks,
> Ken Lynch
> GIS Analyst
> (814)696-7430
*Lynch, Ken
Message 5 of 11 (115 Views)
11-29-1999 11:10 AM in reply to: *Lynch, Ken
I increased the verbosity of the log file and include pertinent parts of it
here. Can anyone tell me why the client queried the server for a license
but didn't receive one?
99-Nov-29 13:48:53: Administra@stationf [0]: Packet from 10.0.0.232 (Local).
99-Nov-29 13:48:53: Administra@stationf [0]: stationf lastping=943901157
(Still up).
99-Nov-29 13:48:53: Administra@stationf [0]: RECV #1 RQ w.
99-Nov-29 13:48:53: Administra@stationf [0]: SEND #1 RP w SAR L 0 TL 4.
99-Nov-29 13:48:53: Administra@stationf [0]: BURY_ZOMBIES: Start.
99-Nov-29 13:48:53: Administra@stationf [0]: BURY_ZOMBIES: Done.
99-Nov-29 13:48:53: Administra@stationf [0]: bury_zombies: Too soon for next
cleanup.
99-Nov-29 13:49:04: Administra@stationf [0]: Packet from 10.0.0.232 (Local).
99-Nov-29 13:49:04: Administra@stationf [0]: stationf lastping=943901157
(Still up).
99-Nov-29 13:49:04: Administra@stationf [0]: RECV #2 RQ w.
99-Nov-29 13:49:04: Administra@stationf [0]: SEND #2 RP w SAR L 0 TL 0.
99-Nov-29 13:49:04: Administra@stationf [0]: bury_zombies: Too soon for next
cleanup.
cleanup.
99-Nov-29 14:00:29: Administra@stationf [0]: Packet from 10.0.0.21 (Remote).
99-Nov-29 14:00:29: KLYNCH@STATION_S [0]: stationf lastping=943901157 (Still
up).
99-Nov-29 14:00:29: KLYNCH@STATION_S [0]: RECV #1 RQ w.
99-Nov-29 14:00:29: KLYNCH@STATION_S [0]: SEND #1 RP w SAR N 0 TL 0.
99-Nov-29 14:00:29: KLYNCH@STATION_S [0]: BURY_ZOMBIES: Start.
99-Nov-29 14:00:29: KLYNCH@STATION_S [0]: BURY_ZOMBIES: Done.
99-Nov-29 14:04:41: KLYNCH@STATION_S [0]: Packet from 10.0.0.232 (Local).
99-Nov-29 14:04:41: KLYNCH@stationf [0]: stationf lastping=943901157 (Still
up).
99-Nov-29 14:04:41: KLYNCH@stationf [0]: RECV #1 RQ w.
99-Nov-29 14:04:41: KLYNCH@stationf [0]: SEND #1 RP w SAR L 0 TL 0.
99-Nov-29 14:04:41: KLYNCH@stationf [0]: BURY_ZOMBIES: Start.
99-Nov-29 14:04:41: KLYNCH@stationf [0]: BURY_ZOMBIES: Done.
99-Nov-29 14:04:41: KLYNCH@stationf [0]: Packet from 10.0.0.232 (Local).
Ken Lynch wrote in message
news:81eml9$2e526@adesknews2.autodesk.com...
that
have
login
to
the
> Thanks,
> Ken Lynch
> GIS Analyst
> (814)696-7430
*Allaire, Yves
Message 6 of 11 (115 Views)
Re:
11-29-1999 12:42 PM in reply to: *Lynch, Ken
The question might sound stupid but, what append when you query the server, does
it "sees" the ADLM server?
> (Still up).
> cleanup.
> (Still up).
> cleanup.
> cleanup.
> up).
> up).
> that
> have
> login
> to
> the
> > Thanks,
> > Ken Lynch
> > GIS Analyst
> > (814)696-7430
*Primary
Message 7 of 11 (115 Views)
Re:
11-29-1999 06:23 PM in reply to: *Lynch, Ken
As an international user the first question i would ask is since map and its
inbuilt autocad generally both require a feature code, are there two feature
codes available from the server adlm or is the autocad component authorised
in a seperate manner?. International can use a dongle, domestic uses
authcodes.
ACAD Map clients should generally be installed as dual network clients not
half standalone half network.
Yves Allaire wrote in message
news:3842E54C.5D36D44@lino.com...
server, does
it
license
(Local).
> > (Still up).
4.
(Local).
4.
next
> > cleanup.
(Local).
> > (Still up).
0.
next
> > cleanup.
(Local).
0.
next
> > cleanup.
(Remote).
(Still
> > up).
(Local).
(Still
> > up).
Server
indicated
> > that
don't
> > have
> > login
PCs
> > to
with
> > the
> > > Thanks,
> > > Ken Lynch
> > > GIS Analyst
> > > (814)696-7430
*Lynch, Ken
Message 8 of 11 (115 Views)
Re:
11-30-1999 04:59 AM in reply to: *Lynch, Ken
Yes the client 'sees' the server. I can ping the server by name from the
client and I can ping the client from the server.
I didn't know that I needed to authorize AutoCAD and Map separately. I am
under the impression that Map is a stand alone product that only needs one
authorization code. I know that it is built on the AutoCAD core, but I
shouldn't need to load and authorize both separately. At least none of the
documentation talks about this.
Yesterday, I tried using a different NT station as a license server, but I
got the same results. I'm at a loss as to what to try next.
Ken Lynch
GIS Analyst
Hollidaysburg, PA
(814)696-7430
*Allaire, Yves
Message 9 of 11 (115 Views)
Re:
11-30-1999 05:31 AM in reply to: *Lynch, Ken
You should have this info when calling the Autodesk rep. though
> Ken Lynch
> GIS Analyst
> Hollidaysburg, PA
> (814)696-7430
*Milana, Jerry
Message 10 of 11 (115 Views)
Re:
11-30-1999 02:34 PM in reply to: *Lynch, Ken
Go to your c:\adlm\key directory, you should have two .lic files in there, if you
see only one, that is your problem. When you got your authorization you should
have received two codes. Each must be entered by running a session of AdLM Admin
for each code.
Jerry Milana,
> > Ken Lynch
> > GIS Analyst
> > Hollidaysburg, PA
> > (814)696-7430
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
