Installation & Licensing
*walter, thomas
Message 1 of 5 (112 Views)
ADLM on NTserver and 4 workstation with lokal AutoCAD2000-i
112 Views, 4 Replies
02-25-2001 07:54 AM
hello,
ourr network-installation shut only be a network-license
1.
First we we installed the autocad2000-i on lokal machines, for 4 times,
c:\autocad-200-i
now the system ask for 30 day to license-key.
2.
On the Nt-Server ( TCP/IP-Protokol available), we installed the ADLM - only.
with ADLM-Admin, we see the SERVER-CODE 1536 / xxxx yyyy zzz aaaa bbbb
? and now ?
are our steps correct?
? where we get the code
the online register at https://register.autodesk.com is not for Network
license
shut we try from outside professional ?
thanks
thomas
*martin, jason
Message 2 of 5 (112 Views)
Re: ADLM on NTserver and 4 workstation with lokal AutoCAD2000-i
02-25-2001 10:31 AM in reply to: *walter, thomas
Thomas -
How did you install autocad on the local machines? Did you install it from
the CD? If so then you should un-install these and create a "client
deployment". To create the client deployment navigate to the \netsetup
folder on the cd and run setup.exe and select client deployment.
Creating a client deployment will require you to place an "image" somewhere
on a server that all of the clients can see. This image will be used to
install autocad on all of the clients. Installing autocad directly from the
cd and trying to get licenses from the adlm server is not supported.
hth
jason martin
frankfurt-short-bruza
thomas walter wrote in message
news:95F17C43697F47AE460AE285E07CB767@in.WebX.maYIadrTaRb...
> hello,
> 1.
> c:\autocad-200-i
> 2.
only.
> ? and now ?
> license
> thanks
> thomas
*martin, jason
Message 3 of 5 (112 Views)
Re:
02-25-2001 10:56 AM in reply to: *walter, thomas
Sorry I didn't finish my post before I posted...
You'll need to call autodesk to get an "authorization" code. The number
that you will need to call should be in the installation guide. Basically
(after finding the correct number) you will call autodesk, they will ask you
your serial number, address, company name and number of licenses (make sure
that you have all of you acad serial number handy, even previous versions if
this is an upgrade). They will then ask you for your server code. Give it
to them and they will give you back a 9 million (okay it's not really that
long) digit authorization code. On the adlm server you will launch adlm
admin (I think) and type in the authorization code. Your adlm will then be
able to issue licenses.
hth
jason
(snip)
> > hello,
> > 1.
> > c:\autocad-200-i
> > 2.
> only.
> > ? and now ?
> > license
> > thanks
> > thomas
*walter, thomas
Message 4 of 5 (112 Views)
Re:
02-26-2001 02:06 AM in reply to: *walter, thomas
hey,
is it "really right" - (EDITED) happens.
in Autocad14 and mechanical 2000, we istalled from CD on lokal herddisk,
copied he adesksys.dll and all was fine.
your opinion, that i have to
- deinstalled the aktuel software and
- create an image on the server first. ?
thomas
"jason martin" schrieb im Newsbeitrag
news:smileyvery-happy:059D83802B9ABE5D308C7A3EB063CC6@in.WebX.maYIadrTaRb...
> Thomas -
from
somewhere
the
> hth
> jason martin
> > hello,
> > 1.
> > c:\autocad-200-i
> > 2.
> only.
> > ? and now ?
> > license
> > thanks
> > thomas
*martin, jason
Message 5 of 5 (112 Views)
Re:
02-26-2001 09:52 AM in reply to: *walter, thomas
Thomas -
Here's my recommendation.
Uninstall autocad from the machines where you used the CD to do the
installation.
From the CD's \netsetup folder run setup.exe and create a client deployment.
Create an installation image on a server that everyone has access to. You
can select different options that you want installed on the client (just
like you were doing a local install, and all the clients are installed the
same).
On each of the clients run the exe located in the root of the share that you
created the installation image on. Make sure that when you are running the
installation on the clients you are using an account with administrative
privileges.
hth
jason martin
news:9C5434C4148676C9034C6336913101D4@in.WebX.maYIadrTaRb...
> hey,
> thomas
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
