• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    Accepted Solution
    ADLM handing out BDS AutoCAD license to ANY Vanilla AutoCAD user...
    173 Views, 11 Replies
    04-17-2012 09:05 AM
    We have network seats of AutoCAD and also a network seat of Building Design Suite Premium (asked our vendor for a standalone, but somehow got a network seat instead). Installed it all this week but found out that the seat for the BDS AutoCAD will be handed out by the ADLM to ANY user who's running vanilla AutoCAD from their station. We've checked and double checked it with the LM Tools utility. The BDS seat is on some kind of "first come first served" condition and it then prohibits the user who SHOULD only have access to that license from obtaining it and, while he will be able to run AutoCAD from the installed BDS package on his decktop (as the ADLM will hand him one of the remaining plain AutoCAD license seats), he cannot then fire up any other products that are part of the BDS.
    The BDS and the AutoCADs have different serial numbers. Seems like that should prohibit this from happening, but it's not.
    Has anyone else seen this?
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: ADLM handing out BDS AutoCAD license to ANY Vanilla AutoCAD user...
    04-17-2012 09:30 AM in reply to: robert
    Active Contributor
    04-17-2012 09:50 AM in reply to: DarrenP
    Not Quite..let's say users A,B,C and D all have network license seats for just AutoCAD.
    User E has the BDS installed.
    So, if User E fires up his station before users ABCD, then he aquires a plan AutoCAD seat and not the BDS seat.
    Also, ANY user can acquire the BDS AutoCAD seat which then resitricts user E from aquiring it and using any product that's part of the BDS because user E is then restricted to using only the "AutoCAD" license.
    *Expert Elite*
    TravisNave
    04-17-2012 09:56 AM in reply to: robert
    If you have just one seat of BDS and one user with that suite installed, then create an adskflex.opt options file to reserve that seat of BDS for that user only.  None of the other users will be able to take it and he'll always have access to it.  That's your best bet.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    DarrenP
    04-17-2012 09:57 AM in reply to: robert
    its working correctly
    according to the cascading sequence: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16981643&linkID=9240657&CMP=OTC-RSS...
    what you can do is create an options to reserve a bds license for the bds user:
    http://forums.autodesk.com/t5/Installation-Licensing/Managing-the-adskflex-opt-Options-File/td-p/307...
    *Expert Elite*
    TravisNave
    04-17-2012 09:57 AM in reply to: DarrenP
    You're fast today, Darren.  :smileyvery-happy:
    Travis Nave
    Active Contributor
    04-17-2012 10:00 AM in reply to: TravisNave
    Ok, so it's not enough to simply reserve the one BDS seat for the BDS user, we must also exclude that user from having access to the AutoCAD seats. So, it has to be done through a combo on includes and exludes, right?
    We don't want the BDS user to aquire a plain AutoCAD seat...and we don't want the plain AutoCAD users from aquiring the BDS seat.
    *Expert Elite*
    TravisNave
    04-17-2012 10:04 AM in reply to: robert
    Not necessarily.  If you reserve the BDS license for the one user then that user will always have that license checked out.  Thus it should query the NLM and simply take the reserve rather than the other license.
    Travis Nave
    Active Contributor
    04-17-2012 10:12 AM in reply to: TravisNave
    We tried the RESERVE and it didn't work for some odd reason.
    I think, though, with a combination of INCLUDE and EXCLUDE we have it working fine.
    Now, how does the TIMEOUT function work for returning licenses? Is the elapsed time measured in computer use or AutoCAD use? And, does the NLM shut down AutoCAD and do a SAVE for all open files, or just dump them or let a user figure out what to do with the files once they return to their station?
    *Expert Elite*
    TravisNave
    04-17-2012 11:19 AM in reply to: robert
    TIMEOUT has a minimum of 900 seconds and works on idle time.  If the computer is idle for that length of time, the license is returned to the pool.  When it is no longer idle, the license is reclaimed.  If there are no licenses available, the application asks the user to save and then the application must close.
    Travis Nave
