Only if the server Authorization code changes. Before you change the IP
address write down the server auth code. Then change the IP address (make
sure you are using a static IP address and not one assigned by a DHCP
server). Now check the server auth code. If it is the same, then you are
"in like Flynn" (or so the saying goes). If it changes then you will have
to re-authorize all your licenses.
One piece of advice, do this when nobody is using AutoCAD, late at night,
early in the morning, on the weekend. Then call the authorization center
ASAP if the server code changed .
HTH
Kevin Nehls
for direct reply, substitute the obvious with the obvious
"Brian M. Heinack" wrote in message
news:E366FAE2ACAB0B1C40AF65B2FF537095@in.WebX.maYIadrTaRb...
| If I change the IP address of a server running ADLM, do I have to
| re-authorize all of the products?
| Thanks,
| Brian Heinack
