• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Dawe, Anthony
    ADLM Problems
    108 Views, 5 Replies
    09-25-2000 01:45 PM
    Hi there,
    We're in the midst of trying to upgrade our AutoCAD R14 to AutoCAD 2000 as
    well as add our LDD and AutoCAD 2000i licences. We've successfully added the
    licences via the 'Winadmin.exe' and can see all of the expected feature codes
    and quantities. The problem arises trying to access the ADLM from the client
    install of any of the updates (R14 still works fine). If I use the
    'Winquery.exe', I can only get information on the '140' feature code. Any
    querys on the other feature codes give a 'NO KEY' response. Thus I can see
    with 'Winadmin' but not with 'Winquery'??? We're on a Novell network running
    the IPX version of ADLM and NT4 workstations.
    Thanx in advance....
    Please use plain text.
    *Diercks, Skip
    Re: ADLM Problems
    09-26-2000 04:52 AM in reply to: *Dawe, Anthony
    Did you stop the ADLM service and restart it after entering your new auth
    codes?
    Skip
    Anthony Dawe wrote in message
    news:8FBAAA748usenetacct@209.90.150.102...
    > Hi there,
    the
    codes
    client
    running
    *Dawe, Anthony
    Re:
    09-26-2000 06:23 AM in reply to: *Dawe, Anthony
    Skip,
    Thanx for your reply...Unfortunately the network manager that performed the
    update is not in today, so I cannot confirm. We will try an unload and
    reload of the ADLM 'After Hours' today.
    sdiercks@wadetrim.com (Skip Diercks) wrote in
    <44110652D200614EC54C71C4C90BF343@in.WebX.SaUCah8kaAW>:
    >codes?
    >Skip
    >> Hi there,
    as
    >the
    >codes
    >client
    Any
    see
    >running
    *Dawe, Anthony
    Re:
    09-27-2000 06:46 AM in reply to: *Dawe, Anthony
    We unloaded and loaded the ADSKELMD.NLM but it made no difference...
    I can see the 140, 150, 152, 153, 160, etc in the 'Winadmin.exe', but only
    have 140 available in the 'Winquery.exe'. I've examined the log file after
    the reload and found that all the new keys are 'Hostcode corrupt'...Looks
    like I've found the problem.
    >codes?
    >Skip
    >> Hi there,
    as
    >the
    >codes
    >client
    Any
    see
    >running
    *Menon, R. Sujith
    Re:
    09-29-2000 06:54 AM in reply to: *Dawe, Anthony
    Hi Anthony
    You can see all the other keys only when the client starts to use autocad(of
    150,152 etc.) in Winquery.exe. Does it show the Server as Active? when you
    click the "Clients" and if your clients have envoked the 150,152 etc autocad
    then you will see those.
    sudhakar
    gl.sudha@hopeindia.com
    > >codes?
    > >Skip
    > >> Hi there,
    > as
    > >the
    > >codes
    > >client
    > Any
    > see
    > >running
    *milana, jerry
    Re:
    10-01-2000 12:43 AM in reply to: *Dawe, Anthony
    Make sure that when you type in the name of your server in AdLM Admin to
    "add server" that you enter it in proper case. For Na Netware AdLM server
    the system name should be entered in UPPER CASE. Entering the name in the
    wrong case will generate a server code but the resulting authorization code
    will produce a license file that will fail authentication.
    jerry milana,
    Autodesk Product Support
    "R. Sujith Menon" wrote in message
    news:39D49F24.D2357329@hopeindia.com...
    > Hi Anthony
    autocad(of
    autocad
    > sudhakar
    only
    after
    corrupt'...Looks
    auth
    > > >codes?
    > > >Skip
    > > >> Hi there,
    2000
    > > as
    added
    > > >the
    feature
    > > >codes
    > > >client
    > > Any
    can
    > > see
    > > >running
