• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Burgasser, Drew
    ADLM Error Message: Unable to obtain HostID
    332 Views, 2 Replies
    05-25-2000 03:47 PM
    A client rebooted their adlm server. The log is shown below. IP addresses
    are x'ed out. What causes the message "Warning: Unable to obtain HostID
    #1...?" I believe that they already tried to re-enter the authorization
    codes.
    00-May-25 13:01:03: Warning: Unable to obtain HostID #1 (ETHER+HISECURE) on
    "wyd_pxy01": System error.
    00-May-25 13:01:03: Host ID failures: pausing 60 seconds and trying again.
    00-May-25 13:02:03: Warning: Unable to obtain HostID #1 (ETHER+HISECURE) on
    00-May-25 13:02:03: Autodesk License Manager - Copyright 1997 Elan Computer
    Group, Inc.
    00-May-25 13:02:03: ADLM 5.0.1c started on wyd_pxy01 (cfd74505).
    00-May-25 13:02:03: Vendor ID = 1a2ccac.
    00-May-25 13:02:03: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
    00-May-25 13:02:03: PID = 362.
    00-May-25 13:02:03: Port = 1422.
    00-May-25 13:02:03: Log file = c:\adlm\LOG\ADLM-52500.LOG.
    00-May-25 13:02:03: Key path = c:\adlm\KEY.
    00-May-25 13:02:03: Keyaccept = 310.
    00-May-25 13:02:03: Resource file = .
    00-May-25 13:02:03: Message level = 3.
    00-May-25 13:02:03: Max log file size = 3145728 bytes.
    00-May-25 13:02:03: Initialization period = 10 seconds.
    00-May-25 13:02:03: Peer registered: "wyd_pxy01" cfd74505 cfd74505
    xxx.xxx.69.5 xxx.xxx.69.5.
    00-May-25 13:02:03: Authorization failure; key c:\adlm\KEY\140.lic only
    valid for: wyd_pxy01.
    00-May-25 13:02:03: Authorization failure; key c:\adlm\KEY\171.lic only
    00-May-25 13:05:32: Warning: Unable to obtain HostID #1 (ETHER+HISECURE) on
    00-May-25 13:05:32: Host ID failures: pausing 60 seconds and trying again.
    Drew Burgasser
    CAD Masters, Inc.
    Please use plain text.
    *Burgasser, Drew
    Re: ADLM Error Message: Unable to obtain HostID
    05-25-2000 04:13 PM in reply to: *Burgasser, Drew
    Nevermind. New auth codes worked.
    Drew Burgasser wrote in message
    news:ef1cb7d.-1@WebX.SaUCah8kaAW...
    addresses
    > codes.
    on
    on
    Computer
    > Group, Inc.
    on
    > Thanks,
    > Drew Burgasser
    > CAD Masters, Inc.
    *milana, jerry
    05-25-2000 04:30 PM in reply to: *Burgasser, Drew
    Drew,
    The "Unable to obtain HostID" message is not a fatal error. It means that
    your network adapter is sloe to fully initialize. AdLM is detecting this
    condition and waiting for the adapter to come up before it authenticates.
    Now, for the fatal error in this log:
    When you see a line like this, AdLM is not going to issue licenses. In this
    case the hostname of the AdLM server is the same as the hostname mentioned
    in the error. This indicates that the Server Code has changed on this
    server since an authorization code was obtained. This can happen for a
    variety of causes. If changes to the network properties have been made or
    the network adapter was changed, the server code cane change. In this case,
    generate a new server code using AdLM Admin, get a new auth code and things
    should remain stable as long as your network properties remain unchanged.
    If however yes to any of the following about your AdLM server, the server
    code can/will float causing continual failure problems, so you will have to
    correct the condition prior to reauthorizing:
    More than one Network Adapter
    RAS (dialup) service enabled as either a RAS Server or RAS Client
    Any other application or service that emulates a network connection
    Server is a DHCP client
    Any of the above will cause dynamic changing of the server's network
    properties, thus causing dynamic failure of AdLM. Again, if any of the
    above are true, that must be resolved prior to attempting to reauthorize or
    this will be a continuing problem.
    Jerry Milana,
    Autodesk Product Support
    "Drew Burgasser" wrote in message
    addresses
    > codes.
    on
    on
    Computer
    > Group, Inc.
    on
    > Thanks,
    > Drew Burgasser
    > CAD Masters, Inc.
