Installation & Licensing
*montagne, michael
Message 1 of 5 (198 Views)
ACADSERVER
198 Views, 4 Replies
06-12-2000 08:56 AM
I'm trying to set the ACADSERVER environment variable in a login script.
The server is NT4.0 as are the workstations. I'm troubled with the syntax.
I can enter SET ACADSERVER BOB in a DOS window and it apears to work, but
when I check in control Panel it didn't. What is the proper syntax and can
this be set in a login script? Why would it not work?
-mjm
*Griffith, Paul
Message 2 of 5 (198 Views)
Re: ACADSERVER
06-12-2000 08:56 AM in reply to: *montagne, michael
> -mjm
Why don't you set the variable in the control panel. If my memory serves
me right, any variables you change/set in a CMD session only exists for
that session, and any process that is started from session.
Paul Griffith
*Diercks, Skip
Message 3 of 5 (198 Views)
Re: ACADSERVER
06-12-2000 11:28 AM in reply to: *montagne, michael
Michael,
    In NT, the variables are saved in the registry.  I
havn't played with the creation of .reg files much, and the syntax necessary to
manipulate the registry using them.  However, the registry is where you
need to make the change.  The .reg file needed to make the change would
look something like this, I think
REGEDIT4
color=#ff0000>[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session
Manager\Environment]
"acadserver"="servername;servername"
everything betweeen the brackets on the HKEY
must be on one line.  There is a space between Session and
Manager.
good luck, Hope this helps.
Skip
michael montagne wrote in
message ...
>I can enter SET
>when I check in
>this be
work?
>-mjm
*montagne, michael
Message 4 of 5 (198 Views)
Re:
06-12-2000 11:48 AM in reply to: *montagne, michael
Thank you. That is the answer I was looking for.  You see
I can't go to every station, I need to run it in a login script.  One thing
that needs to be resolved though.  If I just run this file, it gives me a
dialogue at the end.  How do I make it run quietly?
-mjm
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
Michael,
I havn't played with the creation of .reg files much, and the syntax necessary
to manipulate the registry using them.  However, the registry is where
you need to make the change.  The .reg file needed to make the change
would look something like this, I think
REGEDIT4
Manager.
Skip
message ...
>The server is NT4.0
>I can
but
syntax and can
work?
>-mjm
*montagne, michael
Message 5 of 5 (198 Views)
Re:
06-12-2000 11:58 AM in reply to: *montagne, michael
Got it:  Place "regedit /s regfilename.reg" in a login
script .
thanks for your help
see I can't go to every station, I need to run it in a login script.  One
thing that needs to be resolved though.  If I just run this file, it
gives me a dialogue at the end.  How do I make it run
quietly?
-mjm
Michael,
registry.  I havn't played with the creation of .reg files much, and
the syntax necessary to manipulate the registry using them.  However,
the registry is where you need to make the change.  The .reg file
needed to make the change would look something like this, I think
REGEDIT4
Manager.
Skip
message ...
>The server is
>I
but
syntax and can
work?
>-mjm
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
