Installation & Licensing
Kirke
158 Views, 1 Reply
ACADLT 2013
I have a licensed acadlt 2009 version of AUTOCAD, been using since I purchased in 2009. I have purchased a licence for the 2013 upgrade, however, when I try to install, it says the 2009 version is invalid + I find out the same serial number is shared by an engineering company clear across the US. I am a retired architect doing small commercial architectural work from home so this is important to me. The autdesk people want a copy of the invoice (from 2009).  Can anyone help, thanks
1 REPLY 1
TravisNave
in reply to: Kirke
Unfortunately, if it is showing registered to another entity, you are going to have to work that out with Autodesk or your VAR direct.  This is a peer forum.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
