Installation & Licensing
ACAD not obtaining right licence
1 REPLY 1
245 Views, 1 Reply
Here is the issue:
We have Revit sb 9 (4lic) and Revit sb 9.1(2lic)
when i made network deployment I entered R9.1 serial number. Previously I
installed R9 acad on all computers, when we had R9.1 and now when I
uninstalled R9 acad and deployd R9.1 acad it still takes 52500REVITS_9_0F
licence, but serial number is right.
In licence file I have that serial Nr under 54100REVITS_9_1F
How I can tell to ACAD to user 54100REVITS_9_1F licence? otherwise I cant
run all users using their licences.
Thanks a lot.
pls reply to email too.
Imants
RDS Architect IT
1 REPLY 1
TravisNave
The feature code of the product is built into the program. Serial number means nothing. Therefore only one of two things can possibly be happening:
1. Your installed version of AutoCAD is actually still from the R9, even though you installed with the R9.1 Serial. You need to install AutoCAD from the R9.1 deployment instead.
2. The PLIST option of the license manager is rolling the AutoCAD license over to the next available license. However this seems unlikely given it is a different version.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
