Hi everybody,
I'm trying to install C3D 2012, and at the beginning I had some trouble with result=1619 (the microsoft visual c++ thing) and i already solved that problem..
Now my leftover problem is that i get the error message result=5100 - it exactly says:
6 BK BK-HP === Setup started on BK-HP by BK ===
2012/12/8:16:41:06 BK BK-HP Launch
2012/12/8:16:41:32 BK BK-HP PageOpen LaunchDialog
2012/12/8:16:42:45 BK BK-HP PageOpen LicenseDialog
2012/12/8:16:45:05 BK BK-HP PageOpen ProductInfoDialog
2012/12/8:16:45:37 BK BK-HP PageOpen ProductSelectionDialog2
2012/12/8:16:45:54 BK BK-HP PageOpen FullProgressDialog
2012/12/8:16:45:54 BK BK-HP Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_Civil3D_2012_German_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q
2012/12/8:16:46:02 BK BK-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2012/12/8:16:46:03 BK BK-HP PageOpen InstallCompleteDialog
2012/12/8:16:57:45 BK BK-HP === Setup ended ===
Can you please help me!
thanks
Solved by martin.zikmund.st. Go to Solution.
Solved by hinanaaa. Go to Solution.
got it! 🙂
I removed all .NET Framework things and then installed them again.. I used .NET Framework-Cleanup-Tool and Microsoft .NET Framework 4 (Standalone Installer) and now my ACAD C3D runs 😉
I had the same problem with "Result=5100" and I used CCleaner http://www.piriform.com/ccleaner for cleaning up the registry and Window's useless files. After this you should install Civil3D regulary. GL
