• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Accepted Solution
    ACAD C3D 2012 - Failed installation aborted, Result=5100
    9085 Views, 2 Replies
    12-08-2012 08:21 AM
    Hi everybody,
    I'm trying to install C3D 2012, and at the beginning I had some trouble with result=1619 (the microsoft visual c++ thing) and i already solved that problem..
    Now my leftover problem is that i get the error message result=5100 - it exactly says:
    6    BK    BK-HP    === Setup started on BK-HP by BK ===
    2012/12/8:16:41:06    BK    BK-HP    Launch
    2012/12/8:16:41:32    BK    BK-HP    PageOpen    LaunchDialog
    2012/12/8:16:42:45    BK    BK-HP    PageOpen    LicenseDialog
    2012/12/8:16:45:05    BK    BK-HP    PageOpen    ProductInfoDialog
    2012/12/8:16:45:37    BK    BK-HP    PageOpen    ProductSelectionDialog2
    2012/12/8:16:45:54    BK    BK-HP    PageOpen    FullProgressDialog
    2012/12/8:16:45:54    BK    BK-HP    Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_Civil3D_2012_German_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q
    2012/12/8:16:46:02    BK    BK-HP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=5100
    2012/12/8:16:46:03    BK    BK-HP    PageOpen    InstallCompleteDialog
    2012/12/8:16:57:45    BK    BK-HP    === Setup ended ===
    Can you please help me!
    thanks :smileyhappy:
    Please use plain text.
    New Member
    Re: ACAD C3D 2012 - Failed installation aborted, Result=5100
    12-09-2012 05:57 AM in reply to: hinanaaa
    got it! :smileyhappy:
    I removed all .NET Framework things and then installed them again.. I used .NET Framework-Cleanup-Tool and Microsoft .NET Framework 4 (Standalone Installer) and now my ACAD C3D runs :smileywink:
    New Member
    01-02-2013 06:18 PM in reply to: hinanaaa
    I had the same problem with "Result=5100" and I used CCleaner http://www.piriform.com/ccleaner  for cleaning up the registry and Window's useless files. After this you should install Civil3D regulary. GL
