Installation & Licensing
ACA didn't install during BDS installation
2 REPLIES 2
chris.mckinzie
299 Views, 2 Replies
I was installing the Building Design Suite Ultimate and the ACA failed to install.  However, when I try to run the install for BDS again, it says that ACA is already installed.  ACA also does not show up in the control panel under add/remove programs.  How do I make the suite install allow me to reinstall ACA?
2 REPLIES 2
TravisNave
in reply to: chris.mckinzie
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
If that works for you, try reinstalling again and see if it will go.
Good Luck!
Autodesk Forums:
jeremy.h
in reply to: TravisNave
FYI, Chris was able to install ACA successfully after following the suggestion in Travis' post above.
Jeremy Hanson
Product Support Specialist
Administrator Productivity
