• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Case, Mark
    A2Ki, A2ki Mechanical, MDT 5
    113 Views, 2 Replies
    01-24-2001 07:04 AM
    I have two copies of MDT 5 running TCP/IP(feature codes #272 and #273). I
    want to add 1 each, floating license of A2Ki vanilla and A2Ki Mechanical.
    We have deployed MDT 5 such that all files reside on the client PC.
    The question is can I just add the licenses and use the icons created by
    MDT(for vanilla and mechanical)- - the simple, logical way. -OR- do I have
    to deploy twice more on each users PC. All of our users use all three
    flavors of Acad depending of what types of projects they are working on at
    any moment.
    Mark Case, P.E.
    Sr. Mechanical Engineer
    CaseCAD Engineering
    (509) 773-6247
    web: w3.gorge.net/casecad
    Please use plain text.
    *milana, jerry
    Re: A2Ki, A2ki Mechanical, MDT 5
    01-24-2001 09:43 AM in reply to: *Case, Mark
    Mark,
    AutoCAD 2000i based products each pull a unique license so you will need to
    deploy separately for each.
    jerry milana
    "Mark Case" wrote in message
    news:9D405AEB516D5617C986A0EB53611E8A@in.WebX.SaUCah8kaAW...
    have
    > any moment.
    > Thanks
    > Mark Case, P.E.
    > CaseCAD Engineering
    > (509) 773-6247
    *Case, Mark
    Re:
    01-25-2001 12:36 AM in reply to: *Case, Mark
    Bummer,
    Seems like MOST design groups would want to purchase the number of seats
    required for the degree of 2D and 3D work that they do... This should be
    the strength of a MDT /AcadM / Acad environment.
    Having three deployments is three times as much- - work, hassle, hard drive
    space, etc.
    Thanks for your reply...
    Mark Case, P.E.
    CaseCAD Engineering
    (509) 773-6247
    web: http://w3.gorge.net/casecad
    "jerry milana" wrote in message
    news:259C6721A206650AF4EF6DC9466C63A3@in.WebX.SaUCah8kaAW...
    > Mark,
    to
    > jerry milana
    I
    Mechanical.
    > have
    at
    > > any moment.
    > > Thanks
    > > Mark Case, P.E.
    > > CaseCAD Engineering
    > > (509) 773-6247
