Thank you very much for helping, it is very encouraging to move on..,
now whan i done all that i have "FlexIm Service 1" in window under "Config
using service"
but whan i tried to start MAX9 same messege appears again! "A valid license
could not be obtained by the network licese manager"
I tried to shutdown my firewall and antivirus but nothing..
Whan i am performing status enquiry under SERVER STATUS tab i get this
message
Status
Flexible License Manager status on Wed 11/7/2007 17:06
[Detecting lmgrd processes...]
Error getting status: License server machine is down or not responding.
See the system adminstrator about starting the license server system, or
make sure you're referring to the right host (see LM_LICENSE_FILE).
Hostname: 346-83625352
License path: @346-83625352;
FLEXnet Licensing error:-96,7. System Error: 11004 "WinSock: Valid name,
but no record (NO_ADDRESS)"
It seems to me that something goes wrog with server?
Pls help and thanx,
Kind regards Filip
"Jimmy Bergmark" wrote in message
news:5771472@discussion.autodesk.com...
Use Configuration using Services instead and specify the settings in Config
Services. Make sure to select the checkboxes Use Services and Start Server
at Power Up.
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
"Filip" wrote in message
news:5771275@discussion.autodesk.com...
> Please help me with MAX 9 network licensing 😞
> I did my License File with "Autodesk 3ds Max 9 Network License Activation
> Utility" and save my *.lic file on hard drive
> In LM tools i choosed "Config using License File" but in LMTOOLS under
> Stop/Reread tab i get "License Server Not Found" information.
> Whan i tried to start 3Dmax "FLEXIm License Finder" started up and told
> me:
> "Your app was not able to obtain a license because FLEXnet license server
> manager could not determina where to find the licensing data it needs
> Please
> choose one of the following:
> - Spec. The License Server System
> - Spec. The License File
> I choosed "Spec the License File" and direct it FLEXnet to my
> 3DSMAX9FILIP-PC.lic file on hard drive FLEXnet said: "The FLEXnet license
> finder completed. Press fin to return to app." I clicked FINISH and
> message
> came out:
> "A valid license could not be obtained by the network licese manager."
> "Error (2.5-15)"
> I lost 10 days trying everythign i can not figure it out what happened...
> Can i change network license in one stand license? I am despresed..
