Have you read this article ?
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=10304958&linkID=9240617
Franck Hervet
IT manager
AriCad - France
www.aricad.fr
"mblazer" a écrit dans le message de groupe de discussion :
6284254@discussion.autodesk.com...
> I am running AutoCAD Mechanical 2009 (or trying to) at a remote facility.
> The system (XP SP3) is in a remote site with a ping time of about 200ms to
> the licensing server (2003).
> I found the license file on the workstation and it points to the correct
> server.
> In the main facility no one is having trouble and there are licenses
> available.
> Here is the error message I get:
> A valid license could not be obtained by the network license
> manager. Try again. If you are still unable to access a
> license, contact your system administrator
> Error [1.5-18]
> I increased the FLEXLM_TIMEOUT to 100 000 000 per ID: TS1057817 but it
> does not seem to be waiting 100s, it times out about 7 seconds after the
> splash screen disapears. (I also tried 10 000 000 which did about the
> same). the system has been rebooted.
> Any Ideas?
