Installation & Licensing
A display drive file (.hdl) is missing or has been corrupted.
3 REPLIES 3
ubuntupokemoninc
866 Views, 3 Replies
Hi, I am using autocad electrical 2014 student. and when I turn it on I get this error.
If you need to know my graphics card is a gts 250.
Thanks for your time!
3 REPLIES 3
pendean
in reply to: ubuntupokemoninc
Try removing and reinstalling AutoCAD first.
I tried everything to uninstall it but when I try to reinstall it, it says its still installed Smiley Frustrated
dembkod
ubuntupokemoninc,
Hello. Ms Fixit will clear a residual install:
  http://support.microsoft.com/mats/Program_Install_and_Uninstall\
You are in the graphics realm. First try to shut off Hardware acceleration and see if it helps:
1.) Right-click the program icon on your desktop
2.) Click "Properties"
3.) Access the "Shortcut" tab
4.) In the "Target" field, after acad.exe" type a space and then /NOHARDWARE
5.) Click "OK" and retest
If this does not help, or if it DOES help, download a new graphics card driver and retest. Generally, users prefer to run with the switch not in use. If you update your graphics card driver, you may be able to not use the switch.
When you try to update the driver, do not have Windows search for the driver. Go to the graphics card website: usually Nvidia or ATI and search their site for the latest drivers. I would download 2 or three of the latest available and test them to see if any help.
If this still does not help:
1.)     Uninstall the program through the Control Panel
2.)     Try to uninstall the program again using MSFixit. (This will uninstall a program that lists as already installed): http://support.microsoft.com/mats/Program_Install_and_Uninstall\
3.)     Delete any residual folders for the program from these locations : they should be clearly named:
  • C:\Program Files\Autodesk\
  • C:\ProgramData\Autodesk\
  • C:\Program Files\Common Files\Autodesk\
  • C:\Users\All Users\
  • C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
  • C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
Now install and test.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
