Hi, I had owned max 2011 for months now until two days ago the program stopped working. Everytime i try to open a file or by short cut it won't open at all just an error message. It was working fine a few days ago. I tried to look for help online; I tried reinstalling, updating service packs, i kept the max files to my system deleted and back again, and started running as administrator to name a few but still get the same error.
I tried but i don't know what to do. I feel like I'm making it worse. Please help me.Thank you.
My Computer info::
windows vista 2007
service pack 2
Processor: Intel Core Duo @ 1.83GHz
RAM: 3.0 GB
32 bit
129 GB free out of 231GB
The error looks like this::
Hi rinkuchan;
Most likely there is something that has changed on the system since the time it was working, anything new installed or updated including other software packages?
Unfortunately, the error itself doesn't show anything overly helpful. There's a couple things you can try to see if it helps
1. Create a new user on the system and log in as that user to see if it's a problem with your user account. If it is you can reset your prefs by renaming the ini file. The link below will help with that
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14095997&linkID=9241177
2. Try resetting your licensing, this may require that you re-activate depending on how you are licensed
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15890817&linkID=9241177
3. Try doing a full 'clean unininstall' and re-install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11028514&linkID=9241177
4. Most likely not the issue but you can try to remove and re-install the video card drivers to the latest version.
Dwayne
hi, same thing happend to me, i was worikng in 3ds when error has ocured, then i try to open file, i has been broken so i leave it alone, but this error also apper when i try to launch whole studio, reinstalation with deleting registers didnt help, if you found out what is wrong, i will be really happy if you share your solution, i will try to find out to what is wrong, if i get something i will let you know.
Did everything you wrote, but did not help. What to do? Help, please!
I have 3DS max design 2013
Try doing a system restore back to when it did work.
