Installation & Licensing
3dsmasx failed to install
2 REPLIES 2
dirk
297 Views, 2 Replies
hi there
My 3dsmax 2014 64bit does not want to install. The install process counts down from 9 to 6(installing 3dsMax) then counts mup and fails.
I have tried the following:
 - disabled antivirus.
 - turned off UAC
 - Run As Administrator
These did not work.
I have attached the install log file. if someone can tell me what the problem is I will appreciate it very much.
2 REPLIES 2
david.lau
in reply to: dirk
My suggestion is to use a browser download of the software.  It can be found via step 3 (Virtual Agent ) here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
David Lau
TravisNave
in reply to: dirk
Looks to me like you have redirected profile folders (i.e. My Documents) that is likely causing some of your errors.
You need to temporarily put those back local and make sure you are installing from your hard drive and not from physical external media.  Also, do not include any updates to the software during installation.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
