Installation & Licensing
Active Member
pawwilon
Message 1 of 19 (24,648 Views)
Accepted Solution
3ds max on Windows8
24648 Views, 18 Replies
10-26-2012 03:52 PM
I have 3ds max 2013 edu version, but I cant get it to work on Windows 8, it hands right after clicking 'I agree' on the license window - i.e it disapepars and splash with 'initializing 3ds max' stays there forever,
is this a known issue, and is there a way to solve it ?
I have tried compatibility mode and run as admin already
*Expert Elite*
DarrenP
Message 2 of 19 (24,638 Views)
Re: 3ds max on Windows8
10-26-2012 07:23 PM in reply to: pawwilon
no autodesk products are suppoerted on windows 8
Active Member
pawwilon
Message 3 of 19 (24,600 Views)
what?
10-27-2012 07:52 AM in reply to: DarrenP
What do you mean they arent supported?
From what I know official release date of Win8 was yesterday, so I hope you will finally support it at some point?
New Member
Message 4 of 19 (24,499 Views)
10-28-2012 03:11 PM in reply to: pawwilon
I understand, not supported on Windows 8. I'm trying to reinstall 3ds Max 2012 and I'm finding it will only install as 32bit. I might be missing something in installation. Any suggestions?
Active Member
pawwilon
Message 5 of 19 (24,431 Views)
10-29-2012 04:07 PM in reply to: jrhottel
Any progress?
I know its only a student version and I havent paid you few thousand <insert currency here>, but it might change if I get to work on it to pass my uni :smileyhappy:
Product Support
Message 6 of 19 (24,283 Views)
11-01-2012 09:33 AM in reply to: pawwilon
pawwilon,
Hello. Windows 8 was unavailable as a full product during the development cycle of our products, so it could not effectively be tested against this system. As a result, our existing products are unsupported in this environment. Windows 8 is brand new and the 2013 release was in the spring. Testing had to occur months before that point, and planning months before that.
Based on prior release history, I would expect Windows 8 to be an environment we support on future versions. The same thing happened when Windows 7 was released.
http://upandready.typepad.com/up_and_ready/2012/11/the-joy-of-windows-8-and-anything-new.html
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Product Support
Message 7 of 19 (22,752 Views)
12-10-2012 08:45 AM in reply to: dembkod
pawwilon,
Hello. Just following up. We have produced a list of programs that are expected to work on Windows 8. 3ds max is one of them:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Windows 8 operates in a similar but different fashion, as such, you may run into additional hurdles. Turn off Windows UAC in windows 8- this is different than in Win7.
http://www.forumswindows8.com/tutorials/disable-uac-windows-8-a-4070.htm
Turn off Antivirus and any competing programs.
Check your installed programs list, if you have a program called "Displaylinkcore" uninstall it, you can reinstall after. This driver has caused blocakage in the past on some versions.
Then try to install. If this does not work, look at the processes and programs that are running, shut the excess ones off, or boot into a diagnostic mode and try to install there.
David Dembkoski
David Dembkoski
Active Member
pawwilon
Message 8 of 19 (22,622 Views)
12-12-2012 04:22 PM in reply to: dembkod
Works!
I only had to re-download the package.
New Member
Message 9 of 19 (20,392 Views)
01-22-2013 12:28 PM in reply to: pawwilon
I tried this and it did NOT work.  please give details how you got it to work please.  i'm a teacher and need to work at home to prepare the lessons.  got a new laptop and now I cannot get 3d max 2013 to install.  HELP!
Active Member
pawwilon
Message 10 of 19 (20,345 Views)
01-23-2013 07:06 AM in reply to: pawwilon
If you're on windows 8, did you enable net frameworks?
My problem was corrupt cab file.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
