• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    3ds max installer won't run
    244 Views, 1 Replies
    12-09-2012 08:38 AM
    I downloaded the 3ds 64bit installer but every time I try to run it, it would freeze everything up. It doesn't ever run the installer.
    i do have a 64bit system. I can't even run and start the installer. I have spend 2 hours trying to find out the problem.
    im not using the cd, I'm trying to install the trial for 3ds max
    Please use plain text.
    Active Contributor
    Re: 3ds max installer won't run
    12-09-2012 05:38 PM in reply to: CaptainDuude
    The UAC (User Account Control) should be disabled if this is a Windows 7 or Windows Vista operating System.
    procedure located at website below:
    http://windows.microsoft.com/en-AU/windows-vista/Turn-User-Account-Control-on-or-off
    Install .NET Framework 4.0 separately and then attempt the install...refer procedure below...
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16436702&linkID=9240617
    Any Anti-virus software should be disabled at the time of install...
    Clean out the Windows temp folder:
    1. In windows click Start > Run.
    2. In the Run box type %temp% and click “OK”. A windows explorer window will open and display the files in your TEMP directory.
    3. Select and delete as many files as possible (there may be a few still in use).
    4. Close the explorer window.
    _________________________________________________________________
    KarelCAD Application Support Specialist
