Installation & Licensing
3ds max 2013 and 2014 crashes on startup
1 REPLY 1
asger.gitz
2110 Views, 1 Reply
I have been using 3ds max 2013 for a long time and it has been working perfectly. Then I installed the 2014 version and that worked pretty well.
But suddently OUT OF NOWHERE my 3ds 2014 chrashes. Well that's no problem, I'll just open it up again. Nope. I try again and again. But I keep getting a crash report and I keep sending reports to autodesk. I try to reinstall, but no luck there. Then I try to install the 2013 version but that crashes aswell.
All it does is showing me the small loading screen then it stops at "Starting 3ds MAX" and crashes. I have downloaded the most recent software update for both applications what do I do?
1 REPLY 1
TravisNave
in reply to: asger.gitz
Welcome to the community.
These are sometimes hard to figure out.  This could be a result of a Windows Update or perhaps you need to update your video card driver to a WHQL driver.
You might first try a system restore back to when it worked.  Then update your video card driver.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
