Installation & Licensing
New Member
xxxenigmaxxx
Message 1 of 3 (1,798 Views)
3ds max 2012 Failed to Install
1798 Views, 2 Replies
02-22-2012 05:07 PM
2012/2/22:17:25:44 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:17:25:44 Antonio XXXENIGMAXXX Launch
2012/2/22:17:26:08 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:17:26:09 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:17:30:16 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:17:36:57 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:17:37:31 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:17:39:02 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:17:39:02 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): F:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:17:39:02 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:17:39:03 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:17:39:14 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:17:39:21 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:17:39:21 Antonio XXXENIGMAXXX Launch
2012/2/22:17:39:31 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:17:39:25 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:17:39:25 Antonio XXXENIGMAXXX Launch
2012/2/22:17:39:31 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:17:40:22 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:17:40:28 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:17:40:43 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:17:41:48 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:17:41:48 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): F:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:17:41:48 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:17:41:48 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:17:42:12 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:13:31 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:13:31 Antonio XXXENIGMAXXX Launch
2012/2/22:18:13:54 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:13:32 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:13:32 Antonio XXXENIGMAXXX Launch
2012/2/22:18:13:54 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:14:28 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:14:33 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:18:14:52 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:15:05 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:15:05 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:18:15:05 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:18:15:06 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:18:18:06 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:18:11 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:18:11 Antonio XXXENIGMAXXX Launch
2012/2/22:18:18:17 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:18:17 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:18:41 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:19:39 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:18:19:53 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:20:15 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:20:16 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:18:20:16 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:18:20:16 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:18:23:16 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:23:32 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:23:32 Antonio XXXENIGMAXXX Launch
2012/2/22:18:23:39 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:23:33 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:23:33 Antonio XXXENIGMAXXX Launch
2012/2/22:18:23:38 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:24:04 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:24:06 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:18:24:19 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:24:33 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:24:33 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:18:24:33 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:18:24:33 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:18:25:26 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:25:27 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:25:27 Antonio XXXENIGMAXXX Launch
2012/2/22:18:25:33 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:25:33 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:26:09 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:36:49 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:36:49 Antonio XXXENIGMAXXX Launch
2012/2/22:18:38:02 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:36:54 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:36:54 Antonio XXXENIGMAXXX Launch
2012/2/22:18:38:02 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:38:25 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:38:42 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:18:39:02 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:39:18 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:39:19 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:18:39:19 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:18:39:19 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:18:39:25 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:39:27 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:39:27 Antonio XXXENIGMAXXX Launch
2012/2/22:18:39:32 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:39:32 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:39:54 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:40:00 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:18:40:21 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:40:26 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:40:27 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:18:40:27 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2012/2/22:18:40:27 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:18:40:56 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:41:08 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:41:08 Antonio XXXENIGMAXXX Launch
2012/2/22:18:41:14 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:41:13 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:41:18 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:41:18 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:42:12 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:42:13 Antonio XXXENIGMAXXX Installing Autodesk® 3ds Max 2012 SDK:  TRANSFORMS="C:\Users\Antonio\AppData\Local\Temp\_AID44E.tmp\x86\Tools\MAXSDK\SDK_3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/2/22:18:42:17 Antonio XXXENIGMAXXX Install Autodesk® 3ds Max 2012 SDK Succeeded
2012/2/22:18:42:17 Antonio XXXENIGMAXXX Installing Network License Manager:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/2/22:18:42:21 Antonio XXXENIGMAXXX Install Network License Manager Succeeded
2012/2/22:18:42:21 Antonio XXXENIGMAXXX Installing Allegorithmic Substance Designer: L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\Partners\Allegorithmic\substance_designer.exe
2012/2/22:18:42:21 Antonio XXXENIGMAXXX Install Allegorithmic Substance Designer Failed Failure is ignored, Result=2
2012/2/22:18:42:21 Antonio XXXENIGMAXXX Installing Allegorithmic Substance Player: L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\Partners\Allegorithmic\substance_player.exe
2012/2/22:18:42:21 Antonio XXXENIGMAXXX Install Allegorithmic Substance Player Failed Failure is ignored, Result=2
2012/2/22:18:42:21 Antonio XXXENIGMAXXX Installing ArchVision Dashboard:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/2/22:18:42:28 Antonio XXXENIGMAXXX Install ArchVision Dashboard Succeeded
2012/2/22:18:42:28 Antonio XXXENIGMAXXX Installing Archvision RPC Plug-In:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/2/22:18:42:30 Antonio XXXENIGMAXXX Install Archvision RPC Plug-In Succeeded
2012/2/22:18:42:30 Antonio XXXENIGMAXXX Installing Craft Director Studio: L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\Partners\CraftAnimations\CraftDirectorStudio.exe
2012/2/22:18:42:30 Antonio XXXENIGMAXXX Install Craft Director Studio Failed Failure is ignored, Result=2
2012/2/22:18:42:30 Antonio XXXENIGMAXXX PageOpen InstallCompleteDialog
2012/2/22:18:42:39 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:44:26 Antonio XXXENIGMAXXX === Setup started on XXXENIGMAXXX by Antonio ===
2012/2/22:18:44:26 Antonio XXXENIGMAXXX Launch
2012/2/22:18:45:01 Antonio XXXENIGMAXXX === Setup ended ===
2012/2/22:18:45:01 Antonio XXXENIGMAXXX PageOpen LaunchDialog
2012/2/22:18:45:26 Antonio XXXENIGMAXXX PageOpen LicenseDialog
2012/2/22:18:45:33 Antonio XXXENIGMAXXX PageOpen ProductInfoDialog
2012/2/22:18:45:43 Antonio XXXENIGMAXXX PageOpen ProductSelectionDialog2
2012/2/22:18:46:13 Antonio XXXENIGMAXXX PageOpen FullProgressDialog
2012/2/22:18:46:13 Antonio XXXENIGMAXXX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\RapidShare Games\00 - PROGRAMAS ELEMENTALES\Autodesk 3ds Max 2012 X64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Antonio\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/22:18:46:13 Antonio XXXENIGMAXXX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
My computer :
Asus RAMPAGE II Extreme
Core i7-990X 3.46 GHz Extreme
Memoria HyperX DDR3 2,000mhz 4x6
Nvidia Quadro Fx1800 Hdmi Para Diseño
Sata 3 - 4 Discos duros 6 TB
en breve otro mas de 2tb 6GPS/Sec.
Corsair Cooling Hydro Series H50
4 Coolers 12Cm
1 Cooler de 14Cm
Quemador LiteOn
Fuente de podr Cool master 1000 Watts
Gabinete Cooler Master 690 Ii Advanced Nvidia Edition
Windows 7 x64 ultimate.
TravisNave
Message 2 of 3 (1,760 Views)
Re: 3ds max 2012 Failed to Install
02-24-2012 07:11 AM in reply to: xxxenigmaxxx
Install Mi​crosoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation
Try uninstalling all of your Visual C++ 2005 from Control Panel > Programs and reinstalling.
On a side note, I've also noticed you're installing from your L: drive on a folder for Rapidshare.  Is this is legal downloaded copy from Autodesk?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
fding
Message 3 of 3 (1,414 Views)
04-25-2012 10:58 PM in reply to: xxxenigmaxxx
go to 3rd party folder, and install it seperately.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
