Installation & Licensing
3ds max 2011 instalation failed
5 REPLIES 5
shikharsrivastava23
902 Views, 5 Replies
i was installing the 3ds max 2011 but it failed nothing got installed  neither the back burner and not even the visual c++ stuff
and every time it shows the same thing . i am running windows xp service pack 3
plzz someone help me
i am also giving the log -
2011/7/1:15:02:37StudentPC=== Setup started on PC by Student ===2011/7/1:15:03:13StudentPC=== Setup ended ===
2011/7/1:15:02:52StudentPC=== Setup started on PC by Student ===2011/7/1:15:14:23StudentPCInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedFailure is ignored, Result=16032011/7/1:15:14:47StudentPCInstallDirectX® Runtime UpdateSucceeded2011/7/1:15:14:55StudentPCInstallAutodesk Backburner 2008.1FailedInstallation aborted, Result=16012011/7/1:15:14:56StudentPCRollbackDirectX® Runtime UpdateFailedFailure is ignored, Result=16012011/7/1:15:24:29StudentPCInstallAutodesk 3ds Max 2011 SDKFailedFailure is ignored, Result=16012011/7/1:15:24:33StudentPCInstallAutodesk 3ds Max 2011 SDK Help for Visual StudioFailedFailure is ignored, Result=16012011/7/1:15:24:36StudentPCInstallAutodesk Asset LocatorFailedFailure is ignored, Result=16012011/7/1:15:24:39StudentPCInstallAutodesk Network License ManagerFailedFailure is ignored, Result=16012011/7/1:15:24:42StudentPCInstallJava 2 Runtime Environment, SE v1.4.2_04FailedFailure is ignored, Result=16012011/7/1:15:24:51StudentPCInstallSAMreport-LiteFailedFailure is ignored, Result=16032011/7/1:15:24:54StudentPCInstallArchVision Content ManagerFailedFailure is ignored, Result=16012011/7/1:15:24:58StudentPCInstallRPC Plugin for Autodesk 3ds Max 2011 32-bitFailedFailure is ignored, Result=16012011/7/1:15:25:55StudentPCInstallEASYnat® 2.5 For 3ds Max 2011 32-bitSucceeded2011/7/1:15:25:58StudentPCInstallTurboSquid Tentacles 3dsMax 2011 32-bitFailedFailure is ignored, Result=16012011/7/1:15:26:05StudentPCInstallCraft Director StudioFailedFailure is ignored, Result=12011/7/1:15:26:08StudentPCInstallPixelActive CityScape 1.8.3.34904 Autodesk PromoFailedFailure is ignored, Result=16012011/7/1:15:26:30StudentPCInstallOkino 32-bit Plug-Ins (Demo)Succeeded2011/7/1:15:26:39StudentPCInstallOkino PolyTrans and NuGraf 32-bit (Demo)Succeeded2011/7/1:15:30:51StudentPCInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedFailure is ignored, Result=16032011/7/1:15:31:01StudentPCInstallDirectX® Runtime UpdateSucceeded2011/7/1:15:31:04StudentPCInstallAutodesk Backburner 2008.1FailedInstallation aborted, Result=16012011/7/1:15:31:05StudentPCRollbackDirectX® Runtime UpdateFailedFailure is ignored, Result=16012011/7/1:15:35:34StudentPCInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedFailure is ignored, Result=16032011/7/1:15:35:45StudentPCInstallDirectX® Runtime UpdateSucceeded2011/7/1:15:35:48StudentPCInstallAutodesk Backburner 2008.1FailedInstallation aborted, Result=16012011/7/1:15:35:48StudentPCRollbackDirectX® Runtime UpdateFailedFailure is ignored, Result=16012011/7/1:15:36:02StudentPC=== Setup ended ===
2011/7/1:15:44:14StudentPC=== Setup started on PC by Student ===2011/7/1:15:44:39StudentPC=== Setup ended ===
2011/7/1:15:44:24StudentPC=== Setup started on PC by Student ===2011/7/1:15:47:09StudentPCInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedFailure is ignored, Result=16032011/7/1:15:47:19StudentPCInstallDirectX® Runtime UpdateSucceeded2011/7/1:15:47:22StudentPCInstallAutodesk Backburner 2008.1FailedInstallation aborted, Result=16012011/7/1:15:47:23StudentPCRollbackDirectX® Runtime UpdateFailedFailure is ignored, Result=16012011/7/1:15:47:40StudentPC=== Setup ended ===
2011/7/1:15:52:31StudentPC=== Setup started on PC by Student ===2011/7/1:15:52:50StudentPC=== Setup ended ===
2011/7/1:15:52:36StudentPC=== Setup started on PC by Student ===2011/7/1:15:54:52StudentPCInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedFailure is ignored, Result=16032011/7/1:15:55:02StudentPCInstallDirectX® Runtime UpdateSucceeded2011/7/1:15:55:06StudentPCInstallAutodesk Backburner 2008.1FailedInstallation aborted, Result=16012011/7/1:15:55:06StudentPCRollbackDirectX® Runtime UpdateFailedFailure is ignored, Result=16012011/7/1:15:58:05StudentPC=== Setup ended ===
5 REPLIES 5
please try
http://forums.autodesk.com/t5/Installation-Licensing/Autocad-2011-Installation-trouble-error-1603/td...
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Visual-C-2005-Redistributable-x86-Fai...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
so can i remove the all the versions of visual c++ installed and then run the 3ds max installer ???
will it work and not affect other applications?
Yes you might have some other applications which are dependant VC++ runtime, this is the Microsoft component which shared by many applications.
VC++ runtime would installed when you run the 3ds max installer, if you want you can do this manually too(to fix the error only with VC++ installer)
Hashim Mundol
Autodesk, Inc.
but i have many of vc++ installed shall i remove all of them? this is the list-
Microsoft Visual C++ 2008 Redistributable x86 9.0.30729.17
Microsoft Visual C++ 2008 Redistributable x86 9.0.30729.14148
Microsoft Visual C++ 2008 x86 Redistributable 9.0.30729.30319
and can u tell why does taht runtime uptade stuff fails to install???
Administrator Productivity
