I have tried all of the different ways of downloading and none of them work. Install now gives me error 1335, download now gives me error0x250000ff, and browser install just stops downloading after a while. Does anyone know what to do about this?
Solved by jeffrey.sin. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
i had the same problem(46mb for maya!!??i wish lol...)with all downloads trying the virtual assitant now,bit rediculous that you cant just do it with your browser tho..
edit: just tried to get max and got this error"HTTP Status 404 - /autodesk/SWDLDNET4/2015/3DSMAX/DLM/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R1_dlm.sfx.exe type Status report message /autodesk/SWDLDNET4/2015/3DSMAX/DLM/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R1_dlm.sfx.exe description The requested resource is not available. Apache Tomcat/7.0.42" with the virtual agent!!! really annoying....
i tried it on there and it says that 3ds max 2015 isnt available. "The requested resource is not available" 2014 starts to download fine though so I will just try that.
Hi @ctmurphy,
We are in the process of updating the download link for Autodesk 3ds Max 2015 in the Virtual Agent. In the meantime, you may use this link to download the installer:
Autodesk 3ds Max 2015 Windows 64bit
Hi @Anonymous,
The download link I posted earlier is applicable for any license types of 3ds Max 2015. You can also use that to download and install your student version license provided you already have your serial number on hand.
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried disabling your antivirus software and downloading from the virtual agent. Your antivirus software may be slowing down your download and even blocking it from installing.
i've disabled all my anti virus programs and the fire wall and tried installing it from the virtual assistant and nothing works
it takes 2 hours to download and when it's done it just cancels and then aborts and I don't know what to do anymore
