Installation & Licensing
3ds Max Failed to Install
31 REPLIES 31
Message 1 of 32
franciscoaliberti
2116 Views, 31 Replies
I don't know what else to do. I don't understand very much about computers so I might need some help explaining what's going on.
I tried installing Max 12, both 64 and 32 bit versions and it failed. Then I tried installing Max 11, both bit versions and nothing.
What's going on? I have Windows 7 in this computer and I already had Max 12 installed before I formatted the machine. It's the same computer but now I can't install any Max version.
Please help me. I'm an art student and every week I have an assignment to do on Max.
31 REPLIES 31
Message 21 of 32
I'm sorry, Hashim. But I didn't understand what you meant.
What is "MRsetservice"?
You posted a link. There the guy says that I need to go to Command Prompt and type "netstat -a -b".
The problem is that when I type that it doesn't give me the port that it should, it only says "the requested operation requires elevation".
Also, this Mental Ray thing that you are talking about, is it the renderer?
Message 22 of 32
If you don't have sufficient rights to do a netstat, you probably don't have sufficient rights to install/run your product.  Make sure you have local administrator rights to your machine and have your UAC disabled.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 23 of 32
Yes it is the renderer.
Please follow Travis's advice on disabling UAC, this could be the cause of install failure.
if not try the tweak in this post
http://forums.autodesk.com/t5/Installation-Licensing/Can-t-install-3DS-max-2012-trial/td-p/2987192 (message 6)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 24 of 32
Hi, guys. I did as you said and disabled the UAC. I tried installing again and it failed.
The Log File follows.
2012/3/5:19:37:07 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/3/5:19:37:07 Frank FRANK-PC Launch
2012/3/5:19:38:17 Frank FRANK-PC === Setup ended ===
2012/3/5:19:37:08 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/3/5:19:37:08 Frank FRANK-PC Launch
2012/3/5:19:38:18 Frank FRANK-PC PageOpen LaunchDialog
2012/3/5:19:38:48 Frank FRANK-PC PageOpen LicenseDialog
2012/3/5:19:38:52 Frank FRANK-PC PageOpen ProductInfoDialog
2012/3/5:19:39:20 Frank FRANK-PC PageOpen ProductSelectionDialog2
2012/3/5:19:39:59 Frank FRANK-PC PageOpen FullProgressDialog
2012/3/5:19:39:59 Frank FRANK-PC Installing DirectX® Runtime: D:\Program Files\Autodesk\3rdParty\DirectX\DXSETUP.exe /silent
2012/3/5:19:43:31 Frank FRANK-PC Install DirectX® Runtime Succeeded
2012/3/5:19:43:31 Frank FRANK-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/5:19:43:40 Frank FRANK-PC Install Autodesk Material Library 2012 Succeeded
2012/3/5:19:43:40 Frank FRANK-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/5:19:44:09 Frank FRANK-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/3/5:19:44:09 Frank FRANK-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/5:19:44:58 Frank FRANK-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/3/5:19:44:58 Frank FRANK-PC Installing Autodesk® Backburner 2012: D:\Program Files\Autodesk\x86\Components\backburner\BackburnerCIF.exe
2012/3/5:19:44:59 Frank FRANK-PC Install Autodesk® Backburner 2012 Succeeded
2012/3/5:19:44:59 Frank FRANK-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Frank\AppData\Local\Temp\_AI25D7.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" INSTALLDIR="D:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/5:19:45:10 Frank FRANK-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/3/5:19:45:10 Frank FRANK-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/3/5:19:45:30 Frank FRANK-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/3/5:19:45:43 Frank FRANK-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/3/5:19:45:56 Frank FRANK-PC Rollback Autodesk Material Library 2012 Succeeded
2012/3/5:19:45:56 Frank FRANK-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Hashim, I will try installing it through "diagnostics mode", following the link you posted.
Message 25 of 32
I tried installing in "diagnostics mode" but it also failed.
This is the log file:
2012/3/5:19:45:56 Frank FRANK-PC PageOpen InstallCompleteDialog
2012/3/5:19:51:50 Frank FRANK-PC [Error: 1058] The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
2012/3/5:19:51:50 Frank FRANK-PC === Setup ended ===
2012/3/5:19:58:51 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/3/5:19:58:51 Frank FRANK-PC Launch
2012/3/5:19:59:43 Frank FRANK-PC === Setup ended ===
2012/3/5:19:58:53 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/3/5:19:58:53 Frank FRANK-PC Launch
2012/3/5:19:59:43 Frank FRANK-PC PageOpen LaunchDialog
2012/3/5:19:59:57 Frank FRANK-PC PageOpen LicenseDialog
2012/3/5:19:59:59 Frank FRANK-PC PageOpen ProductInfoDialog
2012/3/5:20:00:17 Frank FRANK-PC PageOpen ProductSelectionDialog2
2012/3/5:20:00:38 Frank FRANK-PC PageOpen FullProgressDialog
2012/3/5:20:00:38 Frank FRANK-PC Installing DirectX® Runtime: D:\Program Files\Autodesk\3rdParty\DirectX\DXSETUP.exe /silent
2012/3/5:20:01:23 Frank FRANK-PC Install DirectX® Runtime Succeeded
2012/3/5:20:01:23 Frank FRANK-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/5:20:01:23 Frank FRANK-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1601
2012/3/5:20:01:23 Frank FRANK-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1601
Message 26 of 32
Have you tried the installation from msi file as mentioned in the other thread ? and not select the Mental ray.
Hashim Mundol
Autodesk, Inc.
Message 27 of 32
It took me a while to understand how to do it but I'm doing it right now.
I'll post the results.
Thank you.
Message 28 of 32
Hashim, it worked! Thank you so much!
I have my midterm due this next Sunday and I can finally work home where I do my best work!
Thank you so much!
Travis, thank you too for the time you put into helping me! I really appreciate it!
Message 29 of 32
By the way, just out of curiosity, what exactly did I do? Lol.
I mean, will I still be able to render in Mental Ray now?!
Message 30 of 32
in reply to: franciscoaliberti
Failure in the installation!!!
I have tried repeatedly to install the free 3ds max 2012 for students, following advice from various forums without success.I need to directly use the program for a school assignment.
(Could you please help me?)
Intallation log file:
2012/4/25: 15:19:31 Alex ALEX-PC === Setup started on ALEX-PC by Alex ===
2012/4/25: 15:19:31 Alex ALEX-PC Launch
2012/4/25: 15:20:08 Alex ALEX-PC === Setup ended ===
2012/4/25: 15:19:33 Alex ALEX-PC === Setup started on ALEX-PC by Alex ===
2012/4/25: 15:19:33 Alex ALEX-PC Launch
2012/4/25: 15:20:09 Alex ALEX-PC PageOpen LaunchDialog
2012/4/25: 15:20:46 Alex ALEX-PC PageOpen BeginDeploymentDialog
2012/4/25: 15:21:14 Alex ALEX-PC PageOpen LaunchDialog
2012/4/25: 15:21:27 Alex ALEX-PC PageOpen LicenseDialog
2012/4/25: 15:21:52 Alex ALEX-PC PageOpen ProductInfoDialog
2012/4/25: 15:23:07 Alex ALEX-PC PageOpen ProductSelectionDialog2
2012/4/25: 15:25:50 Alex ALEX-PC PageOpen FullProgressDialog
2012/4/25: 15:25:50 Alex ALEX-PC Installing DirectX ® Runtime: 😧 \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \ 3rdParty \ DirectX \ DXSETUP.exe / silent
2012/4/25: 15:26:47 Alex ALEX-PC Install DirectX ® Runtime Succeeded
2012/4/25: 15:26:47 Alex ALEX-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT = "D: \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \" FILESINUSETEXT = "" REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:26:56 Alex ALEX-PC Install Autodesk Material Library 2012 Succeeded
2012/4/25: 15:26:56 Alex ALEX-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT = "D: \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \" FILESINUSETEXT = "" REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:27:23 Alex ALEX-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/4/25: 15:27:23 Alex ALEX-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT = "D: \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \" FILESINUSETEXT = "" REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:27:57 Alex ALEX-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/4/25: 15:27:57 Alex ALEX-PC Installing Autodesk ® Backburner 2012: 😧 \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \ x86 \ Components \ backburner \ BackburnerCIF.exe
2012/4/25: 15:28:12 Alex ALEX-PC Install Autodesk ® Backburner 2012 Succeeded
2012/4/25: 15:28:14 Alex ALEX-PC Installing Autodesk ® 3ds Max 2012: TRANSFORMS = "C: \ Users \ Alex \ AppData \ Local \ Temp \ _AI6C2A.tmp \ x64 \ max \ 3dsMax2012-standalone. mst "ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT =" 😧 \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \ "INSTALLDIR =" d: \ Program Files \ Autodesk \ 3ds Max 2012 \ "FILESINUSETEXT =" "REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:28:22 Alex ALEX-PC Install Autodesk ® 3ds Max 2012 Failed Installation aborted, Result = 1603
2012/4/25: 15:28:22 Alex ALEX-PC Rollback Autodesk ® Backburner 2012 Failed Installation aborted, Result = 1619
2012/4/25: 15:28:37 Alex ALEX-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/4/25: 15:28:52 Alex ALEX-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/4/25: 15:29:11 Alex ALEX-PC Rollback Autodesk Material Library 2012 Succeeded
2012/4/25: 15:29:11 Alex ALEX-PC Rollback DirectX ® Runtime Failed Failure is ignored, Result = 1619
What moves should I do to accomplish the installation?
Thank you in advance for your help.
Message 31 of 32
hey i have been following this post asi have had the same probelm with the student version, i was wondering considering you got the other guys to work what you meant by runnig it from the msi file, where is on my computer
Message 32 of 32
ahmadbiopratama
i might have the solution, install DotNet_win 8 or DotNet_win 8.1 or whatever your os. its worked for me. cheers
Administrator Productivity
