I don't know what else to do. I don't understand very much about computers so I might need some help explaining what's going on.
I tried installing Max 12, both 64 and 32 bit versions and it failed. Then I tried installing Max 11, both bit versions and nothing.
What's going on? I have Windows 7 in this computer and I already had Max 12 installed before I formatted the machine. It's the same computer but now I can't install any Max version.
Please help me. I'm an art student and every week I have an assignment to do on Max.
Solved by ahmadbiopratama. Go to Solution.
Please, can someone help me? Doesn't Autodesk have a costumer service of some sort? A number or an e-mail I can contact a specialized employee to help me?
You need to post your error and your installation log file so we can determine the failure. Usually it is due to a prerequisite installer issue like Visual C++.
Thanks. I deleted all Max related files from my computer, followed the video of how to prep the computer for installation, installed .NET 4, rebooted the system, downloaded Max 2012 again and reinstalled. Here is the log file of the failed installation.
Thank you in advance.
Can anyone help me? I don't know what else to do. I can't really use a different software for what I have to do.
Can someone please help me? I'm still having trouble installing 3ds Max. I already posted the installation log files here.
There should be a larger install log file in your %TEMP% folder with additional information on the failure. Zip and attach it here.
Thank you for answering me, Travis. I uploaded everything related to Autodesk and 3ds Max in the %TEMP% folder. If you could be more specific for what I'm looking for I might be able to find more files.
Thank you again for taking the time to help me.
Unfortunately, I am just not finding what is causing your failure. If you are installing with a service pack, do not do this. Install fresh without one.
I don't even know what a "service pack" is. I bought this computer last year and installed 3ds Max 2012 perfectly and used it for a few months. A couple of months ago I had to format this computer and after that I've been having trouble installing 3ds Max again.
Sometimes when you install the product it asks if you also want to install the following updates. Always say no to this.
Are you installing from media or download?
I will reinstall it an pay attention to that.
I'm installing via download.
Okay, so I was installing again and I unchecked the Service Pack option and it still didn't install.
This is the log file:
2012/2/28:10:28:23 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/2/28:10:28:23 Frank FRANK-PC Launch
2012/2/28:10:29:27 Frank FRANK-PC === Setup ended ===
2012/2/28:10:28:24 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/2/28:10:28:24 Frank FRANK-PC Launch
2012/2/28:10:29:28 Frank FRANK-PC PageOpen LaunchDialog
2012/2/28:10:31:24 Frank FRANK-PC PageOpen LicenseDialog
2012/2/28:10:31:24 Frank FRANK-PC PageOpen ProductSelectionDialog2
2012/2/28:10:32:16 Frank FRANK-PC PageOpen LicenseDialog
2012/2/28:10:32:16 Frank FRANK-PC PageOpen LaunchDialog
2012/2/28:10:32:28 Frank FRANK-PC PageOpen LicenseDialog
2012/2/28:10:32:28 Frank FRANK-PC PageOpen ProductSelectionDialog2
2012/2/28:10:33:22 Frank FRANK-PC PageOpen FullProgressDialog
2012/2/28:10:33:22 Frank FRANK-PC Installing Autodesk® 3ds Max 2012 SDK: TRANSFORMS="C:\Users\Frank\AppData\Local\Temp\_AIA724.tmp\x86\Tools\MAXSDK\SDK_3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" INSTALLDIR="D:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:10:34:01 Frank FRANK-PC Install Autodesk® 3ds Max 2012 SDK Succeeded
2012/2/28:10:34:01 Frank FRANK-PC PageOpen InstallCompleteDialog
2012/2/28:10:34:11 Frank FRANK-PC === Setup ended ===
2012/2/28:10:34:23 Frank FRANK-PC === Setup started on FRANK-PC by Frank ===
2012/2/28:10:34:23 Frank FRANK-PC Launch
2012/2/28:10:34:41 Frank FRANK-PC === Setup ended ===
2012/2/28:10:34:41 Frank FRANK-PC PageOpen LaunchDialog
2012/2/28:10:35:10 Frank FRANK-PC PageOpen LicenseDialog
2012/2/28:10:35:10 Frank FRANK-PC PageOpen ProductSelectionDialog2
2012/2/28:10:35:12 Frank FRANK-PC PageOpen LicenseDialog
2012/2/28:10:35:12 Frank FRANK-PC PageOpen LaunchDialog
2012/2/28:10:35:26 Frank FRANK-PC PageOpen LicenseDialog
2012/2/28:10:35:39 Frank FRANK-PC PageOpen ProductInfoDialog
2012/2/28:10:36:14 Frank FRANK-PC PageOpen ProductSelectionDialog2
2012/2/28:10:36:59 Frank FRANK-PC PageOpen FullProgressDialog
2012/2/28:10:37:00 Frank FRANK-PC Installing DirectX® Runtime: D:\Program Files\Autodesk\3rdParty\DirectX\DXSETUP.exe /silent
2012/2/28:10:39:13 Frank FRANK-PC Install DirectX® Runtime Succeeded
2012/2/28:10:39:13 Frank FRANK-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:10:39:36 Frank FRANK-PC Install Autodesk Material Library 2012 Succeeded
2012/2/28:10:39:36 Frank FRANK-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:10:40:22 Frank FRANK-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/2/28:10:40:22 Frank FRANK-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:10:41:37 Frank FRANK-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/2/28:10:41:37 Frank FRANK-PC Installing Autodesk® Backburner 2012: D:\Program Files\Autodesk\x86\Components\backburner\BackburnerCIF.exe
2012/2/28:10:41:37 Frank FRANK-PC Install Autodesk® Backburner 2012 Succeeded
2012/2/28:10:41:38 Frank FRANK-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Frank\AppData\Local\Temp\_AI2586.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Program Files\Autodesk\" INSTALLDIR="D:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:10:41:48 Frank FRANK-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/2/28:10:41:48 Frank FRANK-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/2/28:10:42:03 Frank FRANK-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/2/28:10:42:14 Frank FRANK-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/2/28:10:42:28 Frank FRANK-PC Rollback Autodesk Material Library 2012 Succeeded
2012/2/28:10:42:28 Frank FRANK-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Do you think it has anything to do with the serial key?
It's the same serial key I used the first time I installed 3ds Max on this computer.
But it's kind of a new computer now because I formatted it, right?
Nah, serial doesn't matter. The Max itself isn't installing on a generic 1603. But there should be another installation log file in your %TEMP% that will just be for MAX and not the whole setup suite. Might help determine the reason.
Travis, I went back into the %TEMP% file and zipped everything that had "max" in the name.
I hope that helps. 😞
Travis, I understand that maybe you can't help me. Is there any other way for me to get help? Is there a costumer service from Autodesk? Any phone I can call?
Phone support is typically offered thru your Value Added Reseller or your Subscription Gold account.
Error in the log is about MRsetservice.
if you are not using Mental ray service you can try the tweak in this post
http://forums.autodesk.com/t5/Installation-Licensing/Can-t-install-3DS-max-2012-trial/td-p/2987192 (message 6)
Extract from the log showing the Errors.
MSI (s) (B8:50) [18:25:36:040]: Doing action: MRSetService
Action ended 18:25:36: RegisterComPlus. Return value 1.
MSI (s) (B8:50) [18:25:36:040]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'MRSetService'
MSI (s) (B8:24) [18:25:36:091]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI5C4D.tmp, Entrypoint: MRSetService
MSI (s) (B8!40) [18:25:36:262]: PROPERTY CHANGE: Adding MR_PORT_OK property. Its value is '1'.
Action start 18:25:36: MRSetService.
CustomAction MRSetService returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (B8:50) [18:25:36:290]: Machine policy value 'DisableRollback' is 0
MSI (s) (B8:50) [18:25:36:290]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Action ended 18:25:36: MRSetService. Return value 3.
