• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Expert Elite*
    TravisNave
    Re: 3ds Max Design 2013 Insatallatioan Fails
    04-20-2012 01:02 PM in reply to: drblack
    I agree with Darren.  It sounds like your Windows is in pretty bad shape.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    Active Member
    04-20-2012 01:16 PM in reply to: TravisNave
    Can I do that without having to reinstall all of my programs?
    *Expert Elite*
    DarrenP
    04-20-2012 01:19 PM in reply to: drblack
    you can try to repair the OS with the OS disk not guaranteed to work other option is to reformat your hard drive and start from scatch
